LS1021A-IOT DHCP configuration not working
masranipiyush
I have build fsl-image-rds and successfully deployed on LS1021A-IOT board. However, the board fails to acquire IP address from DHCP server. I have checked the network configuration and it is set correctly to DHCP as can been seen below in /etc/network/interfaces:
# /etc/network/interfaces -- configuration file for ifup(8), ifdown(8)
# The loopback interface
auto lo
iface lo inet loopback
# Wireless interfaces
iface wlan0 inet dhcp
        wireless_mode managed
        wireless_essid any
        wpa-driver wext
        wpa-conf /etc/wpa_supplicant.conf
iface atml0 inet dhcp
# Wired or wireless interfaces
auto eth0
iface eth0 inet dhcp
iface eth1 inet dhcp
# Ethernet/RNDIS gadget (g_ether)
# ... or on host side, usbnet and random hwaddr
iface usb0 inet static
        address 192.168.7.2
        netmask 255.255.255.0
        network 192.168.7.0
        gateway 192.168.7.1
# Bluetooth networking
iface bnep0 inet dhcp
Please find my console output attached. Can anyone point me to what can be the issue?
Thanks.
Piyush
Original Attachment has been moved to: console_output.txt.zip
Tags (2)
josefjebavy
I have same problem.
Have you somebody solution?
Josef Jebavý
arunsrk91
Hi Piyush,
Have you figure out any solution for this? Am also facing the same issue. Are you able to assign IP and verify internet availibilty over all interfaces (eth0, eth1, wlan0, wlan1)?
@Freescale , I hope some support documents can be provided for configuring the wifi cards and wpa supplicant for LS1021A-IOT.
Thanks and Regards,
Arun S
