I am using below boot loader example
http://mcuoneclipse.com/2013/04/28/serial-bootloader-for-the-freedom-board-with-processor-expert/
I am working with K64, using Code Warrior 10.6
the boot loader loads the app and work fine with simple small project led_blink.
but when try to load my application project srec file which is pretty big, I am getting Hard fault interrupt after some half the file is loaded.
after debugging using Hardfault processor component, I see it is Fault address error "Precise data bus error" bit set on SCB->CFSR register. I do see fault address loaded in the register SCB->BFAR.
do you know what could be causing this.
