IMX6SX openOCD configuration file
tcmichals
I'm trying to create a new configuration file for the IMX6SX, in mode =0, the chain is |SJC | SDMA| DAP_A9 |DAP_M4
How/where do you get the ID's for each block?  i.e SDMA? DAP_A9? DAP_M4?
# CoreSight Debug Access Port
if { [info exists DAP_TAPID_A9] } {
   set _DAP_TAPID_A9 $DAP_TAPID_A9
} else {
   set _DAP_TAPID_A9 0x1ba00477  <-- How is the number
if { [info exists DAP_TAPID_M4] } {
   set _DAP_TAPID_M4 $DAP_TAPID_M4
} else {
   set _DAP_TAPID_M4 0x1ba00477 <-- Where/How is this ID created?
jtag newtap $_CHIPNAME DAP -irlen 4 -ircapture 0x2 -irmask 0xf \
        -expected-id $_DAP_TAPID_A9
# SDMA / no IDCODE
jtag newtap $_CHIPNAME SDMA -irlen 4 -ircapture 0x0 -irmask 0xf
# SJC
if { [info exists SJC_TAPID] } {
   set _SJC_TAPID SJC_TAPID
} else {
   set _SJC_TAPID 0x0190d01d <-- How is this number created
tcmichals
Here is a working imx6sx.cfg.  The issue was in the reset commands.  Able to stop, single step, load
transport select jtag
# Slow speed to be sure it will work
adapter_khz 1000
if { [info exists CHIPNAME] } {
   set  _CHIPNAME $CHIPNAME
} else {
   set  _CHIPNAME imx6sx
if { [info exists DAP_TAPID] } {
        set _DAP_TAPID $DAP_TAPID
} else {
        set _DAP_TAPID 0x4ba00477
jtag newtap $_CHIPNAME dapM4 -irlen 4 -ircapture 0x01 -irmask 0x0f \
jtag newtap $_CHIPNAME dapA9 -irlen 4 -ircapture 0x01 -irmask 0x0f \
jtag newtap $_CHIPNAME sdma -irlen 5 -ircapture 0x0 -irmask 0x0f \
        -expected-id 0x1
jtag newtap $_CHIPNAME sjc -irlen 4 -ircapture 0x0 -irmask 0x0f \
        -expected-id 0x0891C01D
target create imx6sx.dapM4 cortex_m  -chain-position imx6sx.dapM4
imx6sx.dapM4 configure -event "reset-assert" {
  echo "Reseting ...."
  #cortex_a dbginit
imx6sx.dapM4 configure -event reset-init { m4_init }
proc m4_init { } {
  echo "Reset-init..."
  ; # halt the CPU
  halt
  dap apsel 0
  cortex_m reset_config vectreset
tcmichals
adapter_khz 1000
} else {
} else {
        -expected-id 0x1
  #cortex_a dbginit
proc m4_init { } {
  ; # halt the CPU
  halt
  dap apsel 0
tcmichals
Jesse,
Thank you your help; the configuration script I'm trying to use is for a imx6sx A9/M4, the cfg files you sent are for imx6d, and imx6q.
fatalfeel
Contributor V
look into the cfg file and search ur imx6sx .h file compare of them
do ur own cfg
Yuri
  Using “attribute IDCODE_REGISTER of MX6SLX” from its BSDL file.
SJC_TAPID 0x0891c01d
  As for CoreSight Debug Access Ports (one for A9, and one for M4)
You may try DAP_TAPID 0x4ba00477 or just to skip them as SDMA.
Yuri
tcmichals
I was looking at the BSDL file and trying to figure out how you got the values:
Yes there is  DAP for each core,  so each one will have a different ID? one for the M4 the other for the A9?
Thank you for your help.
tcmichals
OK, I finally have OpenOCD connecting; but still need more information.
OK there are 4 taps:
SJC_0              -  0x0891c01d
SDMA_0          -
ARMCS-DP_0 -
Cortex-A9_0
ARMCS-DP_1
Cortex-M4_0
Here is a start for configuration file for opencod:
# Freescale i.MX6SX series single/dual/quad core processor
} else {
# CoreSight Debug Access Port A9..
} else {
jtag newtap $_CHIPNAME dap -irlen 4 -ircapture 0x01 -irmask 0x0f \
# SDMA / no IDCODE
jtag newtap $_CHIPNAME sdma -irlen 4 -ircapture 0x00 -irmask 0x0f
# System JTAG Controller
        set _SJC_TAPID $SJC_TAPID
} else {
        set _SJC_TAPID 0x0891c01d
#SDMA
set _SJC_TAPID2 0x2191c01d
#DAP for ARM Cortex A9
set _SJC_TAPID3 0x2191e01d
#ARM Cortex A9
set _SJC_TAPID4 0x1191c01d
#DAP for ARM M4
#ARM Cortex M4
#below needs to change to only use the M4 not A9
jtag newtap $_CHIPNAME sjc -irlen 5 -ircapture 0x01 -irmask 0x1f \
        -expected-id $_SJC_TAPID -expected-id $_SJC_TAPID2 \
        -expected-id $_SJC_TAPID3 -expected-id $_SJC_TAPID4
# GDB target: Cortex-A9, using DAP, configuring only one core
# Base addresses of cores:
# ARM Cortex -A9  -  0x82150000
# core 0  -  0x82152000
set _TARGETNAME $_CHIPNAME.cpu.0
#need to change this for M4..
target create $_TARGETNAME cortex_a -chain-position $_CHIPNAME.dap \
        -coreid 0 -dbgbase 0x82150000
# some TCK cycles are required to activate the DEBUG power domain
jtag configure $_CHIPNAME.sjc -event post-reset "runtest 100"
proc imx6_dbginit {target} {
        # General Cortex A8/A9 debug initialisation
        cortex_a dbginit
adapter_khz 1000
$_TARGETNAME configure -event reset-start { adapter_khz 1000 }
        cortex_a dbginit
adapter_khz 1000
$_TARGETNAME configure -event reset-assert-post "imx6_dbginit $_TARGETNAME"
$_TARGETNAME configure -event gdb-attach { halt }
tcmichals
I've done an auto scan... here is was devices were found
adapter speed: 1000 kHz
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
RCLK - adaptive
Info : RCLK (adaptive clock speed) not supported - fallback to 8 kHz
Warn : There are no enabled taps.  AUTO PROBING MIGHT NOT WORK!!
Info : JTAG tap: auto0.tap tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x4)
Info : JTAG tap: auto1.tap tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x4)
Info : TAP auto2.tap does not have IDCODE
Info : JTAG tap: auto3.tap tap/device found: 0x0891c01d (mfg: 0x00e, part: 0x891c, ver: 0x0)
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -irlen 4 -expected-id 0x4ba00477"
Warn : AUTO auto1.tap - use "jtag newtap auto1 tap -irlen 8 -expected-id 0x4ba00477"
Warn : AUTO auto2.tap - use "jtag newtap auto2 tap -irlen 5 -expected-id 0x00000000"
Warn : AUTO auto3.tap - use "jtag newtap auto3 tap -irlen 2 -expected-id 0x0891c01d"
Error: auto3.tap: IR capture error; saw 0x0003 not 0x0001
Warn : Bypassing JTAG setup events due to errors
Warn : gdb services need one or more targets defined
tcmichals
Shown below is the configuration for openOCD (imx6sx.cfg)
Need to enable the clock and start the M4; when the command "monitor reset init " it locks up the A9; some times it does not;  is there some additional registers to setup?
starting openocd:
sudo  ./src/openocd -f interface/ftdi/jtagkey.cfg -f ./tcl/target/imx6sx.cfg
imx6sx.cfg:
adapter_khz 1000
} else {
} else {
        -expected-id 0x1
