I have had some trouble just getting a basic example project to compile with KDS/MQX/SDK.
Here is what I did in a workspace:
1. Imported project of projects: C:\Freescale\KSDK_1.2.0\rtos\mqx\build\kds\workspace_twrk64f120m\build_libs.wsd
2. Build all - works successfully.
3. Imported: C:\Freescale\KSDK_1.2.0\rtos\mqx\mqx\examples\hello\build\kds\hello_twrk64f120m
4. Build the project and I get missing library errors. Specifically cannot find -lksdk_platform_mqx.
I know this has to be something simple since there really is not much too it.
David
Solved! Go to Solution.
I think I found the answer. Here is what I did:
1. Imported project located here and compiled: C:\Freescale\KSDK_1.2.0\lib\ksdk_mqx_lib\kds\K60D10
2. Imported project located here and compiled: C:\Freescale\KSDK_1.2.0\lib\ksdk_platform_lib\kds\K60D10
3. Recompiled the example hello project and everything seems to be fine now.
