Problems with GStreamer 0.10 VPU Plugins on i.MX53
michaeljohn
I'm trying to play an MPEG4 video on an i.MX53 via GStreamer 0.10 with the Freescale VPU plugins. I can play the video with a software decoder(ffdec_mpeg4) fine, but when I switch it out for the VPU decoder(mfw_vpudecoder) the pipeline appears to hang. Can anyone provide suggestions? Is it not possible to just swap decoders like this? I can play the video by calling the VPU directly in C (no GStreamer), so I know support for the VPU is there and working.
GStreamer: 0.10.36
GStreamer-base: 0.10.36
GStreamer-good: 0.10.31
gst-ffmpeg: 0.10.13
gst-fsl-plugin: 2.0.3
firmware-imx: 11.09.01
imx-lib: 11.09.01
Here is the console output for the software decoder (ffdec_mpeg4), this works:
# gst-launch -v filesrc location=/unit_tests/RR5700-test.mkv typefind=true ! aiurdemux ! ffdec_mpeg4 ! mfw_v4lsink
MFW_GST_V4LSINK_PLUGIN 2.0.3 build on May 27 2015 09:55:17.
Setting pipeline to PAUSED ...
/GstPipeline:pipeline0/GstFileSrc:filesrc0.GstPad:src: caps = video/x-matroska
Pipeline is PREROLLING ...
Aiur: 2.0.3
Core: MKVPARSER_01.00.05 build on Jul 28 2011 15:35:30
  mime: video/x-matroska
  file: lib_mkv_parser_arm11_elinux.3.0.so
/GstPipeline:pipeline0/GstAiurDemux:aiurdemux0.GstPad:sink: caps = video/x-matroska
Content Info:
  URI:
  file:///unit_tests/RR5700-test.mkv
  Idx File:
  /root/.aiur/.unit_tests.RR5700-test.mkv.aidx
  Seekable : Yes
  Size(byte): 11363843
Movie Info:
  Seekable : Yes
  Live : No
  Duration : 0:01:30.123000000
  ReadMode : Track
  Track : 2
Track 00[Video]: Enabled
  Duration: 0:01:30.123000000
  Language: eng
  Mime:
  video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)704, height=(in
  t)480, framerate=(fraction)29/1
Track 01[Audio]: Enabled
  Language: eng
  Mime:
  audio/x-ac3, channels=(int)2, rate=(int)44100, bitrate=(int)0
/GstPipeline:pipeline0/ffdec_mpeg4:ffdec_mpeg40.GstPad:sink: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)704, height=(int)480, framerate=(fraction)29/1
/GstPipeline:pipeline0/ffdec_mpeg4:ffdec_mpeg40.GstPad:src: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
>>V4L_SINK: Actually buffer status:
  hardware buffer : 12
  software buffer : 0
/GstPipeline:pipeline0/MFW_GST_V4LSINK_INFO_T:mfw_gst_v4lsink_info_t0.GstPad:sink: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
full screen size:480x272
[V4L Update Display]: left=0, top=0, width=480, height=272
New clock: GstSystemClock
^CCaught interrupt -- handling interrupt.
Interrupt: Stopping pipeline ...
Execution ended after 3757767375 ns.
total time:0:00:03.760337625 ,Render fps:29
Setting pipeline to READY ...
/GstPipeline:pipeline0/MFW_GST_V4LSINK_INFO_T:mfw_gst_v4lsink_info_t0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/ffdec_mpeg4:ffdec_mpeg40.GstPad:src: caps = NULL
/GstPipeline:pipeline0/ffdec_mpeg4:ffdec_mpeg40.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstAiurDemux:aiurdemux0.GstPad:audio_00: caps = NULL
/GstPipeline:pipeline0/GstAiurDemux:aiurdemux0.GstPad:video_00: caps = NULL
/GstPipeline:pipeline0/GstAiurDemux:aiurdemux0.GstPad:sink: caps = NULL
/GstPipeline:pipeline0/GstFileSrc:filesrc0.GstPad:src: caps = NULL
Setting pipeline to NULL ...
Total rendered:112
Freeing pipeline ...
[--->FINALIZE v4l_sink
[--->FINALIZE aiurdemux
This is with the VPU decoder, the output just hangs, the video is not played:
# gst-launch -v  filesrc location=/unit_tests/RR5700-test.mkv typefind=true ! aiurdemux ! multiqueue ! mfw_vpudecoder ! mfw_v4lsink
MFW_GST_V4LSINK_PLUGIN 2.0.3 build on Jun  3 2015 14:35:01.
0:00:00.273655899 20560 default segment start=0, stop=1, last_stop=8315723440075201856, duration=3, rate=0.000000, applied_rate=0.000000, flags=0x00, time=0:00:00.000000000, accum=0:00:00.000000001 DEBUG         mfw_vpudecoder mfw_gst_vpu_decoder.c:3864:mfw_gst_vpudec_change_state: >>VPU_DEC: State: Null to Ready
[INFO]  Product Info: i.MX53
VPU Version: firmware 1.4.41; libvpu: 5.3.2
MFW_GST_VPU_DECODER_PLUGIN 2.0.3 build on Jun  3 2015 14:34:53.
0:00:00.295671273 20560 default segment start=0, stop=1, last_stop=8315723440075201856, duration=3, rate=0.000000, applied_rate=0.000000, flags=0x00, time=0:00:00.000000000, accum=0:00:00.000000001 DEBUG         mfw_vpudecoder mfw_gst_vpu_decoder.c:4011:mfw_gst_vpudec_change_state: >>VPU_DEC: State Change 0xa for VPU returned 1
0:00:00.296021148 20560 default segment start=0, stop=1, last_stop=8315723440075201856, duration=3, rate=0.000000, applied_rate=0.000000, flags=0x00, time=0:00:00.000000000, accum=0:00:00.000000001 DEBUG         mfw_vpudecoder mfw_gst_vpu_decoder.c:4141:mfw_gst_vpudec_change_state: >>VPU_DEC: State unhandled next 0xa
0:00:00.298102523 20560 default segment start=0, stop=1, last_stop=8315723440075201856, duration=3, rate=0.000000, applied_rate=0.000000, flags=0x00, time=0:00:00.000000000, accum=0:00:00.000000001 DEBUG         mfw_vpudecoder mfw_gst_vpu_decoder.c:3906:mfw_gst_vpudec_change_state: >>VPU_DEC: State: Ready to Paused
0:00:00.298489273 20560 default segment start=0, stop=1, last_stop=8315723440075201856, duration=3, rate=0.000000, applied_rate=0.000000, flags=0x00, time=0:00:00.000000000, accum=0:00:00.000000001 DEBUG         mfw_vpudecoder mfw_gst_vpu_decoder.c:4011:mfw_gst_vpudec_change_state: >>VPU_DEC: State Change 0x13 for VPU returned 1
0:00:00.298732898 20560 default segment start=0, stop=1, last_stop=8315723440075201856, duration=3, rate=0.000000, applied_rate=0.000000, flags=0x00, time=0:00:00.000000000, accum=0:00:00.000000001 DEBUG         mfw_vpudecoder mfw_gst_vpu_decoder.c:4141:mfw_gst_vpudec_change_state: >>VPU_DEC: State unhandled next 0x13
Aiur: 2.0.3
Content Info:
        URI:
        Idx File:
        Seekable  : Yes
Movie Info:
        Seekable  : Yes
        Live      : No
        ReadMode  : Track
        Track     : 2
        Language: eng
        Mime:
        Language: eng
        Mime:
/GstPipeline:pipeline0/GstMultiQueue:multiqueue0.GstPad:sink0: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)704, height=(int)480, framerate=(fraction)29/1
/GstPipeline:pipeline0/GstMultiQueue:multiqueue0.GstPad:src0: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)704, height=(int)480, framerate=(fraction)29/1
Appreciate suggestions.
Thanks.
Labels (3)
Tags (3)
joanxie
could you play the video using playbin2? the command like "gst-launch playbin2 uri=file:///" then tell me the result and put the log file.
michaeljohn
Yes, I can play the video using playbin2.
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: ring-buffer-max-size = 0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: buffer-size = -1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: buffer-duration = -1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: use-buffering = FALSE
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: download = FALSE
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: uri = "file:///unit_tests/RR5700-test.mkv"
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: connection-speed = 0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: source = (GstFileSrc) source
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstTypeFindElement:typefind.GstPad:src: caps = video/x-matroska
(gst-launch-0.10:877): GStreamer-CRITICAL **: gst_debug_log_valist: assertion `category != NULL' failed
Aiur: 2.0.3
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstAiurDemux:aiurdemux0.GstPad:sink: caps = video/x-matroska
Content Info:
        URI:
        Idx File:
        Seekable  : Yes
Movie Info:
        Seekable  : Yes
        Live      : No
        ReadMode  : Track
        Track     : 2
        Language: eng
        Mime:
        Language: eng
        Mime:
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0: max-size-buffers = 5
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0: max-size-time = 0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0: max-size-bytes = 2097152
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:sink0: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)704, height=(int)480, framerate=(fraction)29/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:src0: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)704, height=(int)480, framerate=(fraction)29/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMpeg4VParse:mpeg4vparse0.GstPad:sink: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)704, height=(int)480, framerate=(fraction)29/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:sink1: caps = audio/x-ac3, channels=(int)2, rate=(int)44100, bitrate=(int)0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMultiQueue:multiqueue0.GstPad:src1: caps = audio/x-ac3, channels=(int)2, rate=(int)44100, bitrate=(int)0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstAc3Parse:ac3parse0.GstPad:sink: caps = audio/x-ac3, channels=(int)2, rate=(int)44100, bitrate=(int)0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstAc3Parse:ac3parse0.GstPad:src: caps = audio/x-ac3, framed=(boolean)true, rate=(int)44100, channels=(int)2, alignment=(string)frame
Missing element: AC-3 (ATSC A/52) decoder
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstMpeg4VParse:mpeg4vparse0.GstPad:src: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)704, height=(int)480, framerate=(fraction)29/1, systemstream=(boolean)false, profile=(string)simple, level=(string)1, codec_data=(buffer)000001b001000001b58913000001000000012000c48d8e6ff516043c1463000001b24c61766335342e33352e30, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstInputSelector:inputselector0.GstSelectorPad:sink0: always-ok = FALSE
WARNING: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: No decoder available for type 'audio/x-ac3, framed=(boolean)true, rate=(int)44100, channels=(int)2, alignment=(string)frame'.
Additional debug info:
gsturidecodebin.c(874): unknown_type_cb (): /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstCapsFilter:capsfilter0.GstPad:src: caps = audio/x-ac3, framed=(boolean)true, rate=(int)44100, channels=(int)2, alignment=(string)frame
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstCapsFilter:capsfilter0.GstPad:sink: caps = audio/x-ac3, framed=(boolean)true, rate=(int)44100, channels=(int)2, alignment=(string)frame
/GstPlayBin2:playbin20/GstInputSelector:inputselector0: active-pad = (GstSelectorPad) sink0
/GstPlayBin2:playbin20/GstInputSelector:inputselector0.GstSelectorPad:sink0: tags = ((GstTagList*) UNDEFINED segment)
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/ffdec_mpeg4:ffdec_mpeg40.GstPad:sink: caps = video/mpeg, mpegversion=(int)4, parsed=(boolean)true, width=(int)704, height=(int)480, framerate=(fraction)29/1, systemstream=(boolean)false, profile=(string)simple, level=(string)1, codec_data=(buffer)000001b001000001b58913000001000000012000c48d8e6ff516043c1463000001b24c61766335342e33352e30, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0.GstGhostPad:src0: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20.GstDecodePad:src0: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/ffdec_mpeg4:ffdec_mpeg40.GstPad:src: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
        software buffer : 0
/GstPlayBin2:playbin20/GstInputSelector:inputselector0.GstSelectorPad:sink0: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0.GstGhostPad:src0.GstProxyPad:proxypad8: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20.GstDecodePad:src0.GstProxyPad:proxypad4: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstInputSelector:inputselector0.GstPad:src: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstStreamSynchronizer:streamsynchronizer0.GstPad:sink_0: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0.GstGhostPad:video_sink: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0.GstGhostPad:video_sink.GstProxyPad:proxypad9: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstStreamSynchronizer:streamsynchronizer0.GstPad:src_0: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstQueue:vqueue.GstPad:sink: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin.GstGhostPad:sink: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin.GstGhostPad:sink.GstProxyPad:proxypad13: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstQueue:vqueue.GstPad:src: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstPlaySinkVideoConvert:vconv/GstFFMpegCsp:conv.GstPad:src: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstPlaySinkVideoConvert:vconv/GstFFMpegCsp:conv.GstPad:sink: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstPlaySinkVideoConvert:vconv.GstGhostPad:sink: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstPlaySinkVideoConvert:vconv.GstGhostPad:sink.GstProxyPad:proxypad11: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstPlaySinkVideoConvert:vconv.GstGhostPad:src: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstPlaySinkVideoConvert:vconv/GstVideoScale:scale.GstPad:src: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstPlaySinkVideoConvert:vconv/GstVideoScale:scale.GstPad:sink: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink/MFW_GST_V4LSINK_INFO_T:videosink-actual-sink-mfw_v4l.GstPad:sink: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink.GstGhostPad:sink: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstPlaySinkVideoConvert:vconv.GstGhostPad:src.GstProxyPad:proxypad12: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
/GstPlayBin2:playbin20/GstPlaySink:playsink0/GstBin:vbin/GstAutoVideoSink:videosink.GstGhostPad:sink.GstProxyPad:proxypad10: caps = video/x-raw-yuv, width=(int)704, height=(int)480, framerate=(fraction)29/1, format=(fourcc)I420, interlaced=(boolean)false, pixel-aspect-ratio=(fraction)1/1
Got EOS from element "playbin20".
Execution ended after 90111002999 ns.
total time:0:01:30.124088499 ,Render fps:29
Total rendered:2695
This is with CAPS debug on:
# gst-launch playbin2 uri=file:///unit_tests/RR5700-test.mkv
0:00:00.243579647   871 default segment start=0, stop=1131904, last_stop=7380663569253662768, duration=1131936, rate=0.000000, applied_rate=198101266519865662703445861524734449462085253916034189623067233632678500368632113058960314753090159799052785913742406926685562163689022654625978418501426513707008.000000, flags=0x00, time=0:00:00.000267970, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<source:src> get pad caps
0:00:00.244819772   871 default segment start=0, stop=1131904, last_stop=7380663569253662768, duration=1131936, rate=0.000000, applied_rate=198101266519865662703445861524734449462085253916034189623067233632678500368632113058960314753090159799052785913742406926685562163689022654625978418501426513707008.000000, flags=0x00, time=0:00:00.000267970, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<source:src> get pad caps
0:00:00.245344897   871 default segment start=0, stop=1131904, last_stop=7380663569253662768, duration=1131936, rate=0.000000, applied_rate=198101266519865662703445861524734449462085253916034189623067233632678500368632113058960314753090159799052785913742406926685562163689022654625978418501426513707008.000000, flags=0x00, time=0:00:00.000267970, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<source:src> dispatching to pad getcaps function
0:00:00.246067897   871 default segment start=0, stop=1131904, last_stop=7380663569253662768, duration=1131936, rate=0.000000, applied_rate=198101266519865662703445861524734449462085253916034189623067233632678500368632113058960314753090159799052785913742406926685562163689022654625978418501426513707008.000000, flags=0x00, time=0:00:00.000267970, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<source:src> pad getcaps returned UNDEFINED segment
0:00:00.252360397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<source:src> get pad caps
0:00:00.252746897   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<source:src> dispatching to pad getcaps function
0:00:00.253241522   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<source:src> pad getcaps returned UNDEFINED segment
0:00:00.253510397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<decodebin20:sink> get pad caps
0:00:00.253755647   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<decodebin20:sink> dispatching to pad getcaps function
0:00:00.254009397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<typefind:sink> get pad caps
0:00:00.587759272   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<typefind:sink> get pad caps
0:00:00.588040772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2292:gst_pad_get_caps_unlocked:<typefind:sink> using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x122a98, time=0:00:08.591125160, accum=1350:34:00.418025472 with caps (UNKNOWN FORMAT) segment start=1158166669, stop=4295109776, last_stop=267924, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x99f1, time=1363:25:22.985607169, accum=0:00:00.000000000 (UNKNOWN FORMAT) segment start=1158166669, stop=4295109776, last_stop=267924, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x99f1, time=1363:25:22.985607169, accum=0:00:00.000000000
0:00:00.589352022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<decodebin20:sink> pad getcaps returned UNDEFINED segment
0:00:00.589622022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<source:src> src caps UNDEFINED segment
0:00:00.589905397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<decodebin20:sink> sink caps UNDEFINED segment
0:00:00.590192772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:00.591872147   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<source:src> get pad caps
0:00:00.592201897   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<source:src> get pad caps
0:00:00.592461272   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<source:src> dispatching to pad getcaps function
0:00:00.925261272   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<source:src> pad getcaps returned UNDEFINED segment
0:00:00.925702772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<source:src> get pad caps
0:00:00.925973647   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<source:src> get pad caps
0:00:00.926221897   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<source:src> dispatching to pad getcaps function
0:00:00.926684522   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<source:src> pad getcaps returned UNDEFINED segment
0:00:00.963460897   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<typefind:src> caps UNDEFINED segment UNDEFINED segment
(gst-launch-0.10:871): GStreamer-CRITICAL **: gst_debug_log_valist: assertion `category != NULL' failed
0:00:01.036859772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<typefind:src> get pad caps
0:00:01.037288022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<typefind:src> dispatching to pad getcaps function
0:00:01.037760022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstutils.c:2469:gst_pad_get_fixed_caps_func: using pad caps UNDEFINED segment UNDEFINED segment
0:00:01.038071772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<typefind:src> pad getcaps returned UNDEFINED segment
0:00:01.038336897   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<aiurdemux0:sink> get pad caps
0:00:01.038585022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2292:gst_pad_get_caps_unlocked:<aiurdemux0:sink> using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x14b970, time=0:00:08.591292800, accum=660:32:48.772972544 with caps (UNKNOWN FORMAT) segment start=4098706322821080196, stop=553632, last_stop=-326485791591104512, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x16b8319d, time=0:02:17.438953472, accum=0:00:03.376222520 (UNKNOWN FORMAT) segment start=4098706322821080196, stop=553632, last_stop=-326485791591104512, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x16b8319d, time=0:02:17.438953472, accum=0:00:03.376222520
0:00:01.372474772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<typefind:src> src caps UNDEFINED segment
0:00:01.372801147   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<aiurdemux0:sink> sink caps (UNKNOWN FORMAT) segment start=4098706322821080196, stop=553632, last_stop=-326485791591104512, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x16b8319d, time=0:02:17.438953472, accum=0:00:03.376222520
0:00:01.373553272   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:01.374721772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<source:src> get pad caps
0:00:01.375273647   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<source:src> get pad caps
0:00:01.375533397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<source:src> dispatching to pad getcaps function
0:00:01.375797272   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<source:src> pad getcaps returned UNDEFINED segment
0:00:01.376204272   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<source:src> get pad caps
0:00:01.376696522   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<source:src> get pad caps
0:00:01.376952272   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<source:src> dispatching to pad getcaps function
0:00:01.709950397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<source:src> pad getcaps returned UNDEFINED segment
Aiur: 2.0.3
0:00:01.717922022   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<aiurdemux0:sink> caps UNDEFINED segment UNDEFINED segment
Content Info:
        URI:
        Idx File:
        Seekable  : Yes
Movie Info:
        Seekable  : Yes
        Live      : No
        ReadMode  : Track
        Track     : 2
        Language: eng
        Mime:
0:00:01.733996647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<'':video_00> caps UNDEFINED segment UNDEFINED segment
0:00:01.743575772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<aiurdemux0:video_00> get pad caps
0:00:01.743993772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<aiurdemux0:video_00> dispatching to pad getcaps function
0:00:01.744240522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstutils.c:2469:gst_pad_get_fixed_caps_func: using pad caps UNDEFINED segment UNDEFINED segment
0:00:01.744848522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<aiurdemux0:video_00> pad getcaps returned UNDEFINED segment
0:00:01.745129022   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<multiqueue0:sink0> get pad caps
0:00:01.745377772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<multiqueue0:sink0> dispatching to pad getcaps function
0:00:02.078001022   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2439:gst_pad_peer_get_caps:<multiqueue0:src0> get peer caps
0:00:02.078294647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<multiqueue0:sink0> pad getcaps returned UNDEFINED segment
0:00:02.078562522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<aiurdemux0:video_00> src caps UNDEFINED segment
0:00:02.078846772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<multiqueue0:sink0> sink caps UNDEFINED segment
0:00:02.079315897   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:02.087709772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<multiqueue0:src0> get pad caps
0:00:02.088105147   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<multiqueue0:src0> dispatching to pad getcaps function
0:00:02.088387272   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2439:gst_pad_peer_get_caps:<multiqueue0:sink0> get peer caps
0:00:02.088643897   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<aiurdemux0:video_00> get pad caps
0:00:02.089100147   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<aiurdemux0:video_00> get pad caps
0:00:02.089343647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<aiurdemux0:video_00> dispatching to pad getcaps function
0:00:02.422391022   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstutils.c:2469:gst_pad_get_fixed_caps_func: using pad caps UNDEFINED segment UNDEFINED segment
0:00:02.422807647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<aiurdemux0:video_00> pad getcaps returned UNDEFINED segment
0:00:02.423118897   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<multiqueue0:src0> pad getcaps returned UNDEFINED segment
0:00:02.423387397   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<mpeg4vparse0:sink> get pad caps
0:00:02.423847647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<mpeg4vparse0:sink> dispatching to pad getcaps function
0:00:02.424171772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<mpeg4vparse0:sink> pad getcaps returned UNDEFINED segment
0:00:02.424440147   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<multiqueue0:src0> src caps UNDEFINED segment
0:00:02.424765522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<mpeg4vparse0:sink> sink caps UNDEFINED segment
0:00:02.425269522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:02.426205522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<mpeg4vparse0:src> get pad caps
0:00:02.426736022   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<mpeg4vparse0:src> get pad caps
0:00:02.759907772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<mpeg4vparse0:src> dispatching to pad getcaps function
0:00:02.760164147   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstutils.c:2478:gst_pad_get_fixed_caps_func: using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x2bd14020, time=0:00:05.030101040, accum=876958:52:06.089039872 with caps UNDEFINED segment UNDEFINED segment
0:00:02.760803772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<mpeg4vparse0:src> pad getcaps returned UNDEFINED segment
0:00:02.820006522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<mpeg4vparse0:src> get pad caps
0:00:02.820430897   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<mpeg4vparse0:src> dispatching to pad getcaps function
0:00:02.820677022   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstutils.c:2478:gst_pad_get_fixed_caps_func: using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x2bd14020, time=0:00:05.030101040, accum=876958:52:06.089039872 with caps UNDEFINED segment UNDEFINED segment
0:00:02.821544772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<mpeg4vparse0:src> pad getcaps returned UNDEFINED segment
0:00:02.821804272   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<ffdec_mpeg40:sink> get pad caps
0:00:02.822048397   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2292:gst_pad_get_caps_unlocked:<ffdec_mpeg40:sink> using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x2bd337d8, time=0:00:09.325197304, accum=876958:03:59.871016960 with caps UNDEFINED segment UNDEFINED segment
0:00:02.822865897   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<mpeg4vparse0:src> src caps UNDEFINED segment
0:00:02.823143647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<ffdec_mpeg40:sink> sink caps UNDEFINED segment
0:00:03.155724522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:03.156775522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<ffdec_mpeg40:src> get pad caps
0:00:03.157319397   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> get pad caps
0:00:03.157571897   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> dispatching to pad getcaps function
0:00:03.157794272   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstutils.c:2478:gst_pad_get_fixed_caps_func: using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x2bd332c0, time=0:00:05.030228688, accum=876958:38:21.455319040 with caps UNDEFINED segment UNDEFINED segment
0:00:03.158606772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> pad getcaps returned UNDEFINED segment
        Language: eng
        Mime:
0:00:03.167317272   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<'':audio_00> caps UNDEFINED segment UNDEFINED segment
0:00:03.180999772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<aiurdemux0:audio_00> get pad caps
0:00:03.181414147   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<aiurdemux0:audio_00> dispatching to pad getcaps function
0:00:03.181660147   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstutils.c:2469:gst_pad_get_fixed_caps_func: using pad caps UNDEFINED segment UNDEFINED segment
0:00:03.515455022   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<aiurdemux0:audio_00> pad getcaps returned UNDEFINED segment
0:00:03.515777897   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<multiqueue0:sink1> get pad caps
0:00:03.516029272   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<multiqueue0:sink1> dispatching to pad getcaps function
0:00:03.516281522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2439:gst_pad_peer_get_caps:<multiqueue0:src1> get peer caps
0:00:03.516770272   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<multiqueue0:sink1> pad getcaps returned UNDEFINED segment
0:00:03.517035022   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<aiurdemux0:audio_00> src caps UNDEFINED segment
0:00:03.517316522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<multiqueue0:sink1> sink caps UNDEFINED segment
0:00:03.517583272   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:03.524552772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<multiqueue0:src1> get pad caps
0:00:03.525260522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<multiqueue0:src1> dispatching to pad getcaps function
0:00:03.525549397   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2439:gst_pad_peer_get_caps:<multiqueue0:sink1> get peer caps
0:00:03.858499397   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<aiurdemux0:audio_00> get pad caps
0:00:03.858777522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<aiurdemux0:audio_00> get pad caps
0:00:03.859025397   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<aiurdemux0:audio_00> dispatching to pad getcaps function
0:00:03.859253647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstutils.c:2469:gst_pad_get_fixed_caps_func: using pad caps UNDEFINED segment UNDEFINED segment
0:00:03.859552022   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<aiurdemux0:audio_00> pad getcaps returned UNDEFINED segment
0:00:03.860068772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<multiqueue0:src1> pad getcaps returned (UNKNOWN FORMAT) segment start=15815615772098566, stop=13620200960, last_stop=0, duration=735293312, rate=0.000000, applied_rate=0.000000, flags=0xcdf4511, time=0:02:17.438953600, accum=0:00:04.294967296
0:00:03.860802522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<ac3parse0:sink> get pad caps
0:00:03.861262522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<ac3parse0:sink> dispatching to pad getcaps function
0:00:03.861538772   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<ac3parse0:sink> pad getcaps returned UNDEFINED segment
0:00:03.861805647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<multiqueue0:src1> src caps (UNKNOWN FORMAT) segment start=15815615772098566, stop=13620200960, last_stop=0, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0xcdf4511, time=0:02:17.438953600, accum=0:00:04.294967296
0:00:04.195972397   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<ac3parse0:sink> sink caps UNDEFINED segment
0:00:04.196280647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:04.197420272   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<ac3parse0:src> get pad caps
0:00:04.197728647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<ac3parse0:src> get pad caps
0:00:04.197988897   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<ac3parse0:src> dispatching to pad getcaps function
0:00:04.198212272   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstutils.c:2478:gst_pad_get_fixed_caps_func: using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x2bd3c010, time=0:00:05.030264864, accum=877238:40:16.179036160 with caps (UNKNOWN FORMAT) segment start=3078162752775127052, stop=17915165616, last_stop=-4294967296, duration=735292544, rate=0.000000, applied_rate=0.000000, flags=0x75, time=0:02:17.438953600, accum=0:00:08.589934588 (UNKNOWN FORMAT) segment start=3078162752775127052, stop=17915165616, last_stop=-4294967296, duration=735292544, rate=0.000000, applied_rate=0.000000, flags=0x75, time=0:02:17.438953600, accum=0:00:08.589934588
0:00:04.199505647   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<ac3parse0:src> pad getcaps returned (UNKNOWN FORMAT) segment start=3078162752775127052, stop=17915165616, last_stop=-4294967296, duration=735292544, rate=0.000000, applied_rate=0.000000, flags=0x75, time=0:02:17.438953600, accum=0:00:08.589934588
0:00:04.214288522   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<multiqueue0:sink0> caps UNDEFINED segment UNDEFINED segment
0:00:04.215055397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<multiqueue0:src0> caps UNDEFINED segment UNDEFINED segment
0:00:04.548929772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<mpeg4vparse0:sink> caps UNDEFINED segment UNDEFINED segment
0:00:04.217015397   871 default segment start=0, stop=734835808, last_stop=-5114638277596540920, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.001434856, accum=0:00:00.000548496 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<multiqueue0:sink1> caps UNDEFINED segment UNDEFINED segment
0:00:04.550221647   871 default segment start=0, stop=765412448, last_stop=42949672960, duration=3157306910442587624, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735284928, accum=0:00:00.000000000 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<multiqueue0:src1> caps UNDEFINED segment UNDEFINED segment
0:00:04.550750647   871 default segment start=0, stop=765412448, last_stop=42949672960, duration=3157306910442587624, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735284928, accum=0:00:00.000000000 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<ac3parse0:sink> caps UNDEFINED segment UNDEFINED segment
0:00:04.552594272   871 default segment start=0, stop=765412448, last_stop=42949672960, duration=3157306910442587624, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735284928, accum=0:00:00.000000000 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<ac3parse0:src> caps UNDEFINED segment UNDEFINED segment
0:00:04.553720522   871 default segment start=0, stop=765412448, last_stop=42949672960, duration=3157306910442587624, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735284928, accum=0:00:00.000000000 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<capsfilter0:src> caps UNDEFINED segment UNDEFINED segment
0:00:04.561538397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment
0:00:04.564111272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<uridecodebin0:src0> get pad caps
0:00:04.564517772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<uridecodebin0:src0> get pad caps
0:00:04.568790022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<uridecodebin0:src0> dispatching to pad getcaps function
0:00:04.569112272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<decodebin20:src0> get pad caps
0:00:04.902941022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<decodebin20:src0> get pad caps
0:00:04.903277647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<decodebin20:src0> dispatching to pad getcaps function
0:00:04.903562522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<ffdec_mpeg40:src> get pad caps
0:00:04.903830897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> get pad caps
0:00:04.904306022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> dispatching to pad getcaps function
0:00:04.904548397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstutils.c:2478:gst_pad_get_fixed_caps_func: using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x2bd332c0, time=0:00:05.030228688, accum=876958:38:21.455319040 with caps UNDEFINED segment UNDEFINED segment
0:00:04.905227897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> pad getcaps returned UNDEFINED segment
0:00:04.905745522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<decodebin20:src0> pad getcaps returned UNDEFINED segment
0:00:04.906055647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<uridecodebin0:src0> pad getcaps returned UNDEFINED segment
0:00:04.909024772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<uridecodebin0:src0> get pad caps
0:00:05.241896022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<uridecodebin0:src0> dispatching to pad getcaps function
0:00:05.242345272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<decodebin20:src0> get pad caps
0:00:05.242633647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<decodebin20:src0> get pad caps
0:00:05.243104647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<decodebin20:src0> dispatching to pad getcaps function
0:00:05.243374647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<ffdec_mpeg40:src> get pad caps
0:00:05.243632647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> get pad caps
0:00:05.243891522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> dispatching to pad getcaps function
0:00:05.244125772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstutils.c:2478:gst_pad_get_fixed_caps_func: using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x2bd332c0, time=0:00:05.030228688, accum=876958:38:21.455319040 with caps UNDEFINED segment UNDEFINED segment
0:00:05.245038772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> pad getcaps returned UNDEFINED segment
0:00:05.245353147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<decodebin20:src0> pad getcaps returned UNDEFINED segment
WARNING: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0: No decoder available for type 'audio/x-ac3, framed=(boolean)true, rate=(int)44100, channels=(int)2, alignment=(string)frame'.
Additional debug info:
gsturidecodebin.c(874): unknown_type_cb (): /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0
0:00:05.578816022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<uridecodebin0:src0> pad getcaps returned UNDEFINED segment
0:00:05.579389272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<inputselector0:sink0> get pad caps
0:00:05.579653522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<inputselector0:sink0> dispatching to pad getcaps function
0:00:05.579927022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2396:gst_pad_peer_get_caps_reffed:<inputselector0:src> get peer caps
0:00:05.580199897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<inputselector0:sink0> pad getcaps returned UNDEFINED segment
0:00:05.580686522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<uridecodebin0:src0> src caps UNDEFINED segment
0:00:05.580978147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<inputselector0:sink0> sink caps UNDEFINED segment
0:00:05.581252772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:05.582915897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<inputselector0:src> get pad caps
0:00:05.916767397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<inputselector0:src> dispatching to pad getcaps function
0:00:05.917091397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<inputselector0:src> pad getcaps returned UNDEFINED segment
0:00:05.917375397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<playsink0:video_sink> get pad caps
0:00:05.917631147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<playsink0:video_sink> dispatching to pad getcaps function
0:00:05.918114272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<playsink0:video_sink> pad getcaps returned UNDEFINED segment
0:00:05.918388272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<inputselector0:src> src caps UNDEFINED segment
0:00:05.918672397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<playsink0:video_sink> sink caps UNDEFINED segment
0:00:05.918943772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:05.921132022   871 default segment start=0, stop=765412448, last_stop=42949672960, duration=3157306910442587624, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735284928, accum=0:00:00.000000000 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<capsfilter0:sink> caps UNDEFINED segment UNDEFINED segment
0:00:05.922728147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2976:gst_pad_get_negotiated_caps:<inputselector0:src> negotiated caps (NULL)
0:00:06.255643147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<inputselector0:src> get pad caps
0:00:06.255951397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<inputselector0:src> get pad caps
0:00:06.256217897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<inputselector0:src> dispatching to pad getcaps function
0:00:06.256484647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2396:gst_pad_peer_get_caps_reffed:<inputselector0:sink0> get peer caps
0:00:06.256950397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<uridecodebin0:src0> get pad caps
0:00:06.257209272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<uridecodebin0:src0> get pad caps
0:00:06.257462522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<uridecodebin0:src0> dispatching to pad getcaps function
0:00:06.257724772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<decodebin20:src0> get pad caps
0:00:06.257981397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<decodebin20:src0> get pad caps
0:00:06.258448397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<decodebin20:src0> dispatching to pad getcaps function
0:00:06.258703772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<ffdec_mpeg40:src> get pad caps
0:00:06.591720022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> get pad caps
0:00:06.591995022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> dispatching to pad getcaps function
0:00:06.592237522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstutils.c:2478:gst_pad_get_fixed_caps_func: using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x2bd332c0, time=0:00:05.030228688, accum=876958:38:21.455319040 with caps UNDEFINED segment UNDEFINED segment
0:00:06.593072147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> pad getcaps returned UNDEFINED segment
0:00:06.593375772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<decodebin20:src0> pad getcaps returned UNDEFINED segment
0:00:06.593671772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<uridecodebin0:src0> pad getcaps returned UNDEFINED segment
0:00:06.593944772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<inputselector0:src> pad getcaps returned UNDEFINED segment
MFW_GST_V4LSINK_PLUGIN 2.0.3 build on Jun  3 2015 14:35:01.
0:00:06.609221647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:06.609840147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:06.610122272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> dispatching to pad getcaps function
0:00:06.943150522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> pad getcaps returned UNDEFINED segment
0:00:06.998212147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<conv:src> src caps UNDEFINED segment
0:00:06.998899272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<scale:sink> sink caps UNDEFINED segment
0:00:06.999282647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:06.999714147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<conv:sink> get pad caps
0:00:07.000204772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<conv:sink> get pad caps
0:00:07.000456272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<conv:sink> dispatching to pad getcaps function
0:00:07.000717022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2396:gst_pad_peer_get_caps_reffed:<conv:src> get peer caps
0:00:07.000969397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<scale:sink> get pad caps
0:00:07.001423272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<scale:sink> get pad caps
0:00:07.001669147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<scale:sink> dispatching to pad getcaps function
0:00:07.001917522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2396:gst_pad_peer_get_caps_reffed:<scale:src> get peer caps
0:00:07.351078647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<scale:sink> pad getcaps returned UNDEFINED segment
0:00:07.431338647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<conv:sink> pad getcaps returned UNDEFINED segment
0:00:07.432380022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1878:gst_pad_link_check_compatible_unlocked:<vqueue:src> src caps UNDEFINED segment
0:00:07.432745647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1880:gst_pad_link_check_compatible_unlocked:<vconv:sink> sink caps UNDEFINED segment
0:00:07.433030147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:07.433705022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<vconv:src> get pad caps
0:00:07.433989647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<vconv:src> get pad caps
0:00:07.434248647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<vconv:src> dispatching to pad getcaps function
0:00:07.434803272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<vqueue:src> get pad caps
0:00:07.435080647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<vqueue:src> get pad caps
0:00:07.435337272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<vqueue:src> dispatching to pad getcaps function
0:00:07.435629022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2439:gst_pad_peer_get_caps:<vqueue:sink> get peer caps
0:00:07.436112897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<vqueue:src> pad getcaps returned UNDEFINED segment
0:00:07.770194647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<vconv:src> pad getcaps returned UNDEFINED segment
0:00:07.770542022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink:sink> get pad caps
0:00:07.771032647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink:sink> get pad caps
0:00:07.771292772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink:sink> dispatching to pad getcaps function
0:00:07.771571522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:07.771840522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:07.772315772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> dispatching to pad getcaps function
0:00:07.772608522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> pad getcaps returned UNDEFINED segment
0:00:07.772896772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink:sink> pad getcaps returned UNDEFINED segment
0:00:07.773258147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:1898:gst_pad_link_check_compatible_unlocked: caps are compatible
0:00:08.125912022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2976:gst_pad_get_negotiated_caps:<vqueue:src> negotiated caps (NULL)
0:00:08.126604897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<vqueue:src> get pad caps
0:00:08.126855522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<vqueue:src> get pad caps
0:00:08.127086147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<vqueue:src> dispatching to pad getcaps function
0:00:08.127329397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2439:gst_pad_peer_get_caps:<vqueue:sink> get peer caps
0:00:08.127787897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<sink:proxypad13> get pad caps
0:00:08.128022022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<sink:proxypad13> get pad caps
0:00:08.128249647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<sink:proxypad13> dispatching to pad getcaps function
0:00:08.128488147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<streamsynchronizer0:src_0> get pad caps
0:00:08.128719022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<streamsynchronizer0:src_0> get pad caps
0:00:08.129157147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<streamsynchronizer0:src_0> dispatching to pad getcaps function
0:00:08.129400147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2439:gst_pad_peer_get_caps:<streamsynchronizer0:sink_0> get peer caps
0:00:08.462521522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<video_sink:proxypad9> get pad caps
0:00:08.462801897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<video_sink:proxypad9> get pad caps
0:00:08.463034022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<video_sink:proxypad9> dispatching to pad getcaps function
0:00:08.463270022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<inputselector0:src> get pad caps
0:00:08.463499397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<inputselector0:src> get pad caps
0:00:08.463943647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<inputselector0:src> dispatching to pad getcaps function
0:00:08.464196272   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2396:gst_pad_peer_get_caps_reffed:<inputselector0:sink0> get peer caps
0:00:08.464434647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<uridecodebin0:src0> get pad caps
0:00:08.464718022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<uridecodebin0:src0> get pad caps
0:00:08.464968772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<uridecodebin0:src0> dispatching to pad getcaps function
0:00:08.465421272   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<decodebin20:src0> get pad caps
0:00:08.465654772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<decodebin20:src0> get pad caps
0:00:08.798587522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<decodebin20:src0> dispatching to pad getcaps function
0:00:08.798851522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<ffdec_mpeg40:src> get pad caps
0:00:08.799089647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> get pad caps
0:00:08.799318022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> dispatching to pad getcaps function
0:00:08.799526647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstutils.c:2478:gst_pad_get_fixed_caps_func: using pad template (UNKNOWN FORMAT) segment start=0, stop=0, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x2bd332c0, time=0:00:05.030228688, accum=876958:38:21.455319040 with caps UNDEFINED segment UNDEFINED segment
0:00:08.800335647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<ffdec_mpeg40:src> pad getcaps returned UNDEFINED segment
0:00:08.800609647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<decodebin20:src0> pad getcaps returned UNDEFINED segment
0:00:08.800880022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<uridecodebin0:src0> pad getcaps returned UNDEFINED segment
0:00:08.801348522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<inputselector0:src> pad getcaps returned UNDEFINED segment
0:00:08.801596647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<video_sink:proxypad9> pad getcaps returned UNDEFINED segment
0:00:08.801846397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<streamsynchronizer0:src_0> pad getcaps returned UNDEFINED segment
0:00:08.132579147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment
0:00:09.139016772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<ffdec_mpeg40:src> caps UNDEFINED segment UNDEFINED segment
0:00:09.139627147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<decodebin20:src0> caps UNDEFINED segment UNDEFINED segment
0:00:09.140285022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<uridecodebin0:src0> caps UNDEFINED segment UNDEFINED segment
0:00:09.140905772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<sink:proxypad13> pad getcaps returned UNDEFINED segment
0:00:09.141212522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745095680 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<vqueue:src> pad getcaps returned UNDEFINED segment
0:00:09.156852272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<scale:sink> accept caps of UNDEFINED segment
0:00:09.157275772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<scale:sink> get pad caps
0:00:09.157552022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<scale:sink> get pad caps
0:00:09.157818397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<scale:sink> dispatching to pad getcaps function
0:00:09.158299022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2396:gst_pad_peer_get_caps_reffed:<scale:src> get peer caps
0:00:09.491636897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<src:proxypad12> get pad caps
0:00:09.491934522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<src:proxypad12> get pad caps
0:00:09.492203772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<src:proxypad12> dispatching to pad getcaps function
0:00:09.492481397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink:sink> get pad caps
0:00:09.492959647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink:sink> get pad caps
0:00:09.493222022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink:sink> dispatching to pad getcaps function
0:00:09.493493772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:09.493756897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:09.494018897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> dispatching to pad getcaps function
0:00:09.494512897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> pad getcaps returned UNDEFINED segment
0:00:09.827712022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink:sink> pad getcaps returned UNDEFINED segment
0:00:09.828184397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<src:proxypad12> pad getcaps returned UNDEFINED segment
0:00:09.842076647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<scale:sink> pad getcaps returned UNDEFINED segment
0:00:09.844028022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<src:proxypad12> accept caps of UNDEFINED segment
0:00:09.844576272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<videosink:sink> accept caps of UNDEFINED segment
0:00:09.844939397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<videosink-actual-sink-mfw_v4l:sink> accept caps of UNDEFINED segment
0:00:09.845243897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:09.845715147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:09.845977647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> dispatching to pad getcaps function
0:00:09.846258022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> pad getcaps returned UNDEFINED segment
>>V4L_SINK: Actually buffer status:
        hardware buffer : 12
        software buffer : 0
0:00:09.881320022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<inputselector0:sink0> caps UNDEFINED segment UNDEFINED segment
0:00:09.882155522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<src0:proxypad8> caps UNDEFINED segment UNDEFINED segment
0:00:10.215529897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<src0:proxypad4> caps UNDEFINED segment UNDEFINED segment
0:00:10.216227147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<inputselector0:src> caps UNDEFINED segment UNDEFINED segment
0:00:10.216915147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<streamsynchronizer0:sink_0> caps UNDEFINED segment UNDEFINED segment
0:00:10.217312272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<playsink0:video_sink> caps UNDEFINED segment UNDEFINED segment
0:00:10.217928147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2976:gst_pad_get_negotiated_caps:<inputselector0:src> negotiated caps UNDEFINED segment
0:00:10.218324397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<video_sink:proxypad9> caps UNDEFINED segment UNDEFINED segment
0:00:10.218786897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<streamsynchronizer0:src_0> caps UNDEFINED segment UNDEFINED segment
0:00:10.219391022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vqueue:sink> caps UNDEFINED segment UNDEFINED segment
0:00:10.219759397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vbin:sink> caps UNDEFINED segment UNDEFINED segment
0:00:10.220140272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<sink:proxypad13> caps UNDEFINED segment UNDEFINED segment
0:00:10.552956397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vqueue:src> caps UNDEFINED segment UNDEFINED segment
0:00:10.553429897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<conv:sink> accept caps of UNDEFINED segment
0:00:10.553740272   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<conv:sink> get pad caps
0:00:10.554194772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<conv:sink> get pad caps
0:00:10.554419397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<conv:sink> dispatching to pad getcaps function
0:00:10.554652647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2396:gst_pad_peer_get_caps_reffed:<conv:src> get peer caps
0:00:10.554937647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<scale:sink> get pad caps
0:00:10.555163022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<scale:sink> get pad caps
0:00:10.555597522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<scale:sink> dispatching to pad getcaps function
0:00:10.555830272   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2396:gst_pad_peer_get_caps_reffed:<scale:src> get peer caps
0:00:10.556064647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<src:proxypad12> get pad caps
0:00:10.556289147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<src:proxypad12> get pad caps
0:00:10.888834897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<src:proxypad12> dispatching to pad getcaps function
0:00:10.889143772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink:sink> get pad caps
0:00:10.889385522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink:sink> get pad caps
0:00:10.889619147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink:sink> dispatching to pad getcaps function
0:00:10.889864397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:10.890316397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:10.890551772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> dispatching to pad getcaps function
0:00:10.890813897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> pad getcaps returned UNDEFINED segment
0:00:10.891072272   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink:sink> pad getcaps returned UNDEFINED segment
0:00:10.891723022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<src:proxypad12> pad getcaps returned UNDEFINED segment
0:00:10.892099272   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<scale:sink> pad getcaps returned UNDEFINED segment
0:00:10.557539522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:11.225095897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:11.248931897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:11.249589522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:11.267181522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:11.268043272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:11.285623897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:11.286547647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:11.320781397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<conv:sink> pad getcaps returned UNDEFINED segment
0:00:11.334562522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<scale:sink> accept caps of UNDEFINED segment
0:00:11.334951397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<scale:sink> get pad caps
0:00:11.335204397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<scale:sink> get pad caps
0:00:11.335439647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<scale:sink> dispatching to pad getcaps function
0:00:11.667959272   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2396:gst_pad_peer_get_caps_reffed:<scale:src> get peer caps
0:00:11.668259147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<src:proxypad12> get pad caps
0:00:11.668501147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<src:proxypad12> get pad caps
0:00:11.668732772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<src:proxypad12> dispatching to pad getcaps function
0:00:11.668976772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink:sink> get pad caps
0:00:11.669428897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink:sink> get pad caps
0:00:11.669665647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink:sink> dispatching to pad getcaps function
0:00:11.669915272   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:11.670162522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:11.670401647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> dispatching to pad getcaps function
0:00:11.670877147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> pad getcaps returned UNDEFINED segment
0:00:12.004032522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink:sink> pad getcaps returned UNDEFINED segment
0:00:12.004477397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<src:proxypad12> pad getcaps returned UNDEFINED segment
0:00:12.004898897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<scale:sink> pad getcaps returned UNDEFINED segment
0:00:12.005645897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<conv:src> caps UNDEFINED segment UNDEFINED segment
0:00:12.006051522   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<conv:sink> caps UNDEFINED segment UNDEFINED segment
0:00:12.006413147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vconv:sink> caps UNDEFINED segment UNDEFINED segment
0:00:12.007003647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<sink:proxypad11> caps UNDEFINED segment UNDEFINED segment
0:00:12.009199022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<src:proxypad12> accept caps of UNDEFINED segment
0:00:12.009752647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<videosink:sink> accept caps of UNDEFINED segment
0:00:12.010038897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<videosink-actual-sink-mfw_v4l:sink> accept caps of UNDEFINED segment
0:00:12.010312647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:12.010553772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:12.344394897   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> dispatching to pad getcaps function
0:00:12.344863022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> pad getcaps returned UNDEFINED segment
0:00:12.345773772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<scale:src> caps UNDEFINED segment UNDEFINED segment
0:00:12.346264397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vconv:src> caps UNDEFINED segment UNDEFINED segment
0:00:12.346733147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<scale:sink> caps UNDEFINED segment UNDEFINED segment
0:00:12.348947397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<src:proxypad12> accept caps of UNDEFINED segment
0:00:12.349284647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<videosink:sink> accept caps of UNDEFINED segment
0:00:12.349789647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2617:gst_pad_accept_caps:<videosink-actual-sink-mfw_v4l:sink> accept caps of UNDEFINED segment
0:00:12.350070772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2336:gst_pad_get_caps_reffed:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:12.350319022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2246:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> get pad caps
0:00:12.350560022   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2250:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> dispatching to pad getcaps function
0:00:12.683219147   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2263:gst_pad_get_caps_unlocked:<videosink-actual-sink-mfw_v4l:sink> pad getcaps returned UNDEFINED segment
0:00:12.683987647   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<videosink-actual-sink-mfw_v4l:sink> caps UNDEFINED segment UNDEFINED segment
0:00:12.684606272   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<videosink:sink> caps UNDEFINED segment UNDEFINED segment
0:00:12.685012772   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<src:proxypad12> caps UNDEFINED segment UNDEFINED segment
0:00:12.685493397   871 default segment start=0, stop=774612064, last_stop=0, duration=0, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.745097712, accum=0:00:00.745081728 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<sink:proxypad10> caps UNDEFINED segment UNDEFINED segment
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
full screen size:480x272
[V4L Update Display]: left=0, top=0, width=480, height=272
0:00:12.696524147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:12.697360772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
New clock: GstSystemClock
0:00:12.776244022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:12.776896647   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:12.789565522   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps default segment start=16, stop=745088896, last_stop=0, duration=17180620512, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:02:17.438953600, accum=0:00:00.000000000 default segment start=16, stop=745088896, last_stop=0, duration=17180620512, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:02:17.438953600, accum=0:00:00.000000000 same as existing, updating ptr only
0:00:12.793255022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps default segment start=16, stop=745088896, last_stop=0, duration=17180620512, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:02:17.438953600, accum=0:00:00.000000000 default segment start=16, stop=745088896, last_stop=0, duration=17180620512, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:02:17.438953600, accum=0:00:00.000000000 same as existing, updating ptr only
0:00:13.137702147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.138342897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.147235397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.147947272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.157504772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.158378897   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.165714397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps default segment start=16, stop=745088896, last_stop=0, duration=17180620512, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:02:17.438953600, accum=0:00:00.000000000 default segment start=16, stop=745088896, last_stop=0, duration=17180620512, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:02:17.438953600, accum=0:00:00.000000000 same as existing, updating ptr only
0:00:13.167075272   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps default segment start=16, stop=745088896, last_stop=0, duration=17180620512, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:02:17.438953600, accum=0:00:00.000000000 default segment start=16, stop=745088896, last_stop=0, duration=17180620512, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:02:17.438953600, accum=0:00:00.000000000 same as existing, updating ptr only
0:00:13.179380397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.512507147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.519691397   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.520347022   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.529547772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.530416772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps UNDEFINED segment UNDEFINED segment same as existing, updating ptr only
0:00:13.536952147   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<mpeg4vparse0:src> caps default segment start=-6662858722781429724, stop=735352128, last_stop=7731468468884602917, duration=745038208, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:00:00.000000000, accum=864065:49:47.615281153 default segment start=-6662858722781429724, stop=735352128, last_stop=7731468468884602917, duration=745038208, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:00:00.000000000, accum=864065:49:47.615281153 same as existing, updating ptr only
0:00:13.538742772   871 default segment start=0, stop=744485984, last_stop=85899346151, duration=3202384868546787544, rate=0.000000, applied_rate=0.000000, flags=0x01, time=0:00:00.735126608, accum=889551:21:07.811807320 DEBUG               GST_CAPS gstpad.c:2762:gst_pad_set_caps:<ffdec_mpeg40:sink> caps default segment start=-6662858722781429724, stop=735352128, last_stop=7731468468884602917, duration=745038208, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:00:00.000000000, accum=864065:49:47.615281153 default segment start=-6662858722781429724, stop=735352128, last_stop=7731468468884602917, duration=745038208, rate=0.000000, applied_rate=0.000000, flags=0x2b2b33dc, time=0:00:00.000000000, accum=864065:49:47.615281153 same as existing, updating ptr only
ERROR: from element /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstAiurDemux:aiurdemux0: GStreamer encountered a general stream error.
Additional debug info:
aiurdemux.c(3872): aiurdemux_pull_task (): /GstPlayBin2:playbin20/GstURIDecodeBin:uridecodebin0/GstDecodeBin2:decodebin20/GstAiurDemux:aiurdemux0:
streaming stopped, reason error, state 3
Execution ended after 840745000 ns.
Setting pipeline to PAUSED ...
total time:0:00:01.188914250 ,Render fps:5
Setting pipeline to READY ...
0:00:13.883328022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<videosink-actual-sink-mfw_v4l:sink> caps (NULL) (NULL)
0:00:13.884149272   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<videosink:sink> caps (NULL) (NULL)
0:00:13.885052647   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vconv:src> caps (NULL) (NULL)
0:00:13.885889147   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<scale:src> caps (NULL) (NULL)
0:00:13.886349772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<scale:sink> caps (NULL) (NULL)
0:00:13.887430772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<conv:src> caps (NULL) (NULL)
0:00:13.887818397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<conv:sink> caps (NULL) (NULL)
0:00:13.888746022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vconv:sink> caps (NULL) (NULL)
0:00:13.890375147   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vqueue:src> caps (NULL) (NULL)
0:00:13.890800397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vqueue:sink> caps (NULL) (NULL)
0:00:13.891557897   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<vbin:sink> caps (NULL) (NULL)
0:00:14.225096772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<streamsynchronizer0:sink_0> caps (NULL) (NULL)
0:00:14.225476022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<streamsynchronizer0:src_0> caps (NULL) (NULL)
0:00:14.226191647   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<playsink0:video_sink> caps (NULL) (NULL)
Total rendered:7
0:00:14.260387397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<inputselector0:sink0> caps (NULL) (NULL)
0:00:14.261074522   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<inputselector0:src> caps (NULL) (NULL)
0:00:14.261620397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<uridecodebin0:src0> caps (NULL) (NULL)
0:00:14.262348522   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<decodebin20:src0> caps (NULL) (NULL)
0:00:14.263049147   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<capsfilter0:src> caps (NULL) (NULL)
0:00:14.263618397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<capsfilter0:sink> caps (NULL) (NULL)
0:00:14.264182022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<ac3parse0:src> caps (NULL) (NULL)
0:00:14.264531772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<ac3parse0:sink> caps (NULL) (NULL)
0:00:14.265438522   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<ffdec_mpeg40:src> caps (NULL) (NULL)
0:00:14.598530897   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<ffdec_mpeg40:sink> caps (NULL) (NULL)
0:00:14.599972772   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<mpeg4vparse0:src> caps (NULL) (NULL)
0:00:14.600416897   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<mpeg4vparse0:sink> caps (NULL) (NULL)
0:00:14.602026397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<multiqueue0:sink1> caps (NULL) (NULL)
0:00:14.602658022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<multiqueue0:src1> caps (NULL) (NULL)
0:00:14.602999397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<multiqueue0:sink0> caps (NULL) (NULL)
0:00:14.603322522   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<multiqueue0:src0> caps (NULL) (NULL)
0:00:14.604470522   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<aiurdemux0:audio_00> caps (NULL) (NULL)
0:00:14.604949147   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<aiurdemux0:video_00> caps (NULL) (NULL)
0:00:14.605508397   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<aiurdemux0:sink> caps (NULL) (NULL)
0:00:14.610339022   871 default segment start=0, stop=4295109776, last_stop=7380663569253662768, duration=4295109776, rate=0.000000, applied_rate=0.000000, flags=0x00, time=1363:09:20.912932865, accum=0:00:01.130885982 DEBUG               GST_CAPS gstpad.c:2741:gst_pad_set_caps:<typefind:src> caps (NULL) (NULL)
Setting pipeline to NULL ...
[--->FINALIZE aiurdemux
Freeing pipeline ...
