There are 3 x I2S ports in IMX6 and I consider one more I2S, so decided to use ESAI.
Where can I find the way to configure ESAI to I2S mode?
Is there an reference schematic or example code ?
Solved! Go to Solution.
Hi JHY
for ESAI I2S programming one can look at
sect.4.3.1 INTER-IC SOUND (I2S) FORMAT
http://cache.freescale.com/files/dsp/doc/app_note/AN1848.pdf
and reuse SDK ESAI audio example (imx_esai.c)
i.MX 6Series Platform SDK : Bare-metal SDK for the i.MX 6
Hi JHY
