I am looking for sample code to drive the SPI on a K10 I just need a simple implementation, minimal buffering if any. I will let Processor expert do the setup. I only need to send, not receive.
Solved! Go to Solution.
Hello Tom,
You use Processor Expert , when you add SPI component , right click the component, then select "help on component " ,
in the Typical Usage , you will find simple demo .
Alice
Hello Tom,
Alice
