Cannot obtain manifest for imx/fsl-arm-yocto-bsp
brianleslie
repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-3.10.17-1.0.0_ga
Get https://gerrit.googlesource.com/git-repo/clone.bundle
Get git://git.freescale.com/imx/fsl-arm-yocto-bsp.git
fatal: read error: Connection timed out
fatal: cannot obtain manifest git://git.freescale.com/imx/fsl-arm-yocto-bsp.git
Any ideas on what may be causing this?  I am running a nightly build for the project i am working on and my nightly build server is failing to get the repository.
Labels (3)
saurabh206
Senior Contributor III
Hi Brian
Please check the proxy connection if you are working behind the proxy.
