How to change i.MX6DQ Ethernet Transmit Inter-Packet Gap.
satoshishimoda
Senior Contributor I
Hi community,
Our partner have a question about i.MX6SDQ Ethernet.
They tried changing "Transmit Inter-Packet Gap" from 12 to 27.
Then, they executed the following procedure, but the gap was not changed even though register value was changed correctly.
1. Change ENET_TIPG[IPG] to 27.
2. Set ENET_ECR[ETHEREN].
So would you let me know the above procedure was not appropriate?
Satoshi Shimoda
Labels (2)
Tags (3)
