QCVS.4.2.0_PA_and_ARMv7_10.0.3_150403.zip does not contain the Eclipse Freescale Solutions Category to upgrade the Eclipse stock updater.
johnhovey
I'm trying to load the tools to create the RCW for the E5020 QorIQ processor.
I downloaded and installed the base Eclipse software.
eclipse-cpp-juno-SR2-win32-x86_64.zip
The installation guide for the QCVS tool says to point to the zip file:
and I should see both:
QorIQ Configuration and Validation Suite 4.2.0
I only see the QorIQ software.
Anyone know where to get the updater tools?
-jjh
addiyi
You have to use http://freescale.com/lgfiles/updates/Eclipse/QCVS  as update site. The packages for CodeWarrior doesn't contain the Eclipse Freescale Updater, because this action is already included in CodeWarrior.
Adrian
johnhovey
Adrian,
I had tried that site while in the office last night and it could not be found. I think I had some kind of proxy issue because I tried it from home this morning and it worked.
I had access to the solutions group. But after installing the solutions tools, restarting Eclipse and then installing the QorIQ tool, I got errors deep in the install.
I came back in the office where I downloaded the QorIQ tools and tried the install from the local copy and that just now completed successfully.
I asked tech support to check out the network install errors and also figure out why the Eclipse Freescale Solutions Category doesn’t come with the QorIQ download.
Maybe have a separate download for it like the separate the PA and ARM tools.
-jjh
addiyi
On a stock eclipse you should see:
For installing over CodeWarrior for PA or ARMv7, on freescale.com are available offline installation packages or also the update site.
Adrian
