package_deb is broken in the 3.10.53 ga Yocto release
mobiledev
Any package with a slash in the name (like virtual/bluez) causes the debian package manager class to blow up because it only allows letters and a few other special characters in package names.  tools-sdk is broken as well (appears to have duplicate patch files in different layers) but I was able to find and remove that.  Anyone care to fix?
Barry
OtavioSalvador
Senior Contributor II
I am not aware of any problem like that using original Dizzy or upcoming Fido release. It may be something that has been included by Freescale in their patches.
Can you try to reproduce it in FSL Community BSP?
gusarambula
As you mention this appears to be caused by this debian limitation. In the meantime you may use ipk or rpm instead. I’ll let you know if I find more information.
