When  flash in KDS2.0.0 , it error
Fan_xy
Hello
When flash on KDS2.0.0, TWR-K60D100M board,
I click this :
while , it show :
Where am i wrong ?
And when debug ,it can work well .
Thank
ivadorazinova
Hi fan xy,
do not you want to attach the screenshots? Or more specify it?
Iva
Fan_xy
Hi Iva,
Thank for your remainder !
I click this :
while , it show :
Where am i wrong ?
Attachment is my project !
Thank you very much !
fan@
ivadorazinova
Hi fan xy,
it could cause incorrect settings.
Please, check your flash settings.
I hope it helps you.
Iva
davidsherman
Senior Contributor I
It appears it programmed and verified correctly, which is what you would expect if you are trying to flash it.  Looks like it's just reporting that it disconnected after programming and verifying correctly, so what is the error?
