It was erased BANK0 of P4080PCIE by mistake.
After that, there is no message in console when power up.
In this case, what is needed for restoring bootloader?
Solved! Go to Solution.
You should use CodeWarrior for PA to recover the board. Flash Programmer allow you to program the new uboot into the flash. If you want to use Flash Programmer, you have to select S29GL01GP. A preconfigured target task already exists in:
PA_10.0\bin\plugins\support\TargetTask\FlashProgrammer\QorIQ_P4\P4080PCIe_NOR_FLASH.xml.
Please refer to Flash Programmer for CodeWarrior Power Architecture for more information about how to use Flash Programmer.
Adrian
As suggested by Stoica, please download CodeWarrior for PA from Freescale website:
CodeWarrior Dev Tools for Power Architecture|Freescale
The latest version is 10.4 and it contains 30 days evaluation license.
Adrian
