Hi everyone,
I've written some code for the K20 chip, and I'm wondering if it's safe to use a JTAG programmer to copy that code from one chip to another. Is there anything in memory that's perhaps read-only or reserved that could cause problems when dumping the entire memory from one K20 to another?
Marlon
Solved! Go to Solution.
Hi, Martin
This really depends the JTAG programmer. As normal, if programmer support this function, it should be safe.
Best Regards
Paul
Hi, Martin
Best Regards
Paul
