Dear Sir or Madam,
Hello.
I found the below USB Certification report.
USB Certification report of i.Mx6
Does freescale has the USB Certification report of i.MX 6SoloLite.
Best Regards
Keita
Solved! Go to Solution.
Q1: i.MX6Solo and i.MX6DL have same die, they share same TID.
Q2: you can find it in report.
Could someone follow up the question?
Please send me your answer as soon as possible.
Keita
The latest one in the page which you shared is for 6SL.
Hi Lin,
I'd like to know the TIC number.
[Q1]
Is the i.MX6Solo's TID number the same as i.MX6DL (TID 40001472)?
[Q2]
Could you tell me the i.MX6SoloLite's TID number?
Keita
Hi Lin,
Thank you very much!
OK. I got it.
Keita
Hi Lin,
Thank you for your prompt reply.
OK. Thank you
Sorry. I was not able to find this report about i.MX6SL.
Is it share same TID (TID 40001472)?
Keita
