我遇到 Link Error : L1102: Out of allocation space in segment ROM at address 0xFF9F
我用的是 Aw60 单片机 应该有 60K的 程序空间 我的 mapfile 在附件里 程序总的大小 应该 没有 超过60K啊 prm 也在附件里边 能给看看是怎么回事吗?
Original Attachment has been moved to: Project.prm.zip
Original Attachment has been moved to: out.map.txt.zip
I wonder your ROM space is not big enough to load your code, change
to
Then add -OnB=b to your compiler setting.
This should fix the problem.
Jennie Zhang
