Hi,xiaomei
I have find something useful for you as follows:
开机启动服务的关键点是,当android启动完毕后,android会广播一次android.intent.action.BOOT_COMPLETED。如果想在启动后执行自己的代码,需要编写一个广播的接收者,并且注册接收者到这个广播intent上。
这里以android中使用定时任务代码为例,将它的服务改为开机启动。
首先,需要编写一个intent的receiver,比如SmsServiceBootReceiver:
通过这个Receiver,启动SmsService。那么怎么让这个Receiver工作呢,需要把它注册到android系统上,去监听广播的BOOT_COMPLETED intent。在AndroidManifest.xml中:
<?xml version=”1.0″ encoding=”utf-8″?>
<manifest xmlns:android=”http://schemas.android.com/apk/res/android”
package=”com.easymorse” android:versionCode=”1″ android:versionName=”1.0″>
<application android:icon=”@drawable/icon” android:label=”@string/app_name”>
<activity android:name=”.SmsServiceOptions” android:label=”@string/app_name”>
<intent-filter>
<action android:name=”android.intent.action.MAIN” />
<category android:name=”android.intent.category.LAUNCHER” />
</intent-filter>
</activity><service android:name=”.SmsService”>
<intent-filter>
<action android:name=”com.easymorse.SmsService”></action>
</intent-filter>
</service>
<receiver android:name=”SmsServiceBootReceiver”>
<intent-filter>
<action android:name=”android.intent.action.BOOT_COMPLETED”></action>
</intent-filter>
</receiver>
</application>
<uses-sdk android:minSdkVersion=”3″ />
</manifest>
增加黑体字部分的内容即可。
这样重新开机,服务在开机android系统启动完毕后就会加载。再启动Activity绑定(binding)服务,就可以操作SmsService服务,如果Activity解除绑定,也不会shutdown服务了。
if any problems, pls contact me!
yours,
Tony Zheng
Thank you for your reply.
But I don't want to start after android is up. I want to start form my program directly.
Do you means start your special program (or shell) like below?
u-boot --> launch kernel --> init.rc --> "your_special_program" --> Android start
Rick
you want to start your program when the u-boot start?
Or you want to start it after the Android is up?
I want to start my program when the u-boot start rather than the android is up.
you can modify the u-boot source code to run your program directly.
