I am using K60 device in my project and facing issue on RTC and CAN module.
Please find the attached screen shot and code.Here I have tested individual module, but still I am not able to find the success.
I attached the snapshot also for your reference.
With RTC code it is terminated on the Debughault in debug perspective.
With CAN its showing CAN frame send success but still there is no activities on the CAN_Rx & CAN_Tx pin of controller.
Please tell us for the where I am committing the mistake.
Regards.
Anand
Original Attachment has been moved to: RTC_MODULE.rar
Original Attachment has been moved to: CAN_MODULE.rar
Hi Anand,
When did the RTC issue happen? I notice there are three APIs called in that project, RTC1_Init(),RTC1_SetTime() and RTC1_GetTime(). Which one would cause Debughault issue? Please kindly help to clarify.
Thanks for your patience!!
Kan
Hi Anand,
Actually the RTC_MODULE runs well on my side, please kindly refer to the following for details. This demo run on a TWR-K60F120M, not sure the device on your side, would you please help to clarify? Thanks for your patience!!
Kan
Hi Anand,
Unfortunately, I can not open the CAN_MODULE by CW 10.5, would you please help to clarify?
Kan
