I am using iMX6 Sabre-sd board. I am able to boot up the board but I am not able to see the USB debugging option in settings.
Android version 4.2.2.
Model number: SABRESD-MX6DQ
Solved! Go to Solution.
click "Build number" several times quickly, then developer options will be turn on.
Thanks Rick Chu for your help..
Please check the FAQ in the document package (document tab, for latest JB: https://www.freescale.com/webapp/Download?colCode=IMX6_JB422_110_ANDROID_DOCS&location=null&fpsp=1&P...) , USB debugging is part of developper settings menu :
27 How do I enable developer settings on Android 4.2?
Google has hidden the developer settings in the latest version of Jelly Bean. The following steps explain how to retrieve developer settings:
• Go to the settings menu and scroll down to "About phone." Tap it.
• Scroll down to the bottom again until you see "Build number."
• Tap it seven (7) times. After the third tap, you'll see a playful dialog that says you're four taps away from being a
developer.
• Keep on tapping, until you've got the developer settings back.
Cheers, Philippe.
Hello Philippe,
Thanks for your reply. I am able to figured this out.
Thanks for your help.
Niharika.
