I've got some code working on a K20 MCU. Now I am going over to a KL05. I am editing the low level code from the K20 and using ifdefs so I can switch MCUs by changing one define. I am isolating all the register-level code into one .C module so that the rest of the higher level code is MCU independent.
BTW I don't want to use PE. I've got my own libraries I want to build on top of this generic Kinetis library.
So I'm looking for a register-level comparison between the K and the L MCUs. Can anyone direct me to a source for this information? How peripherals vary between MCU variants. etc
TIA
Tom
Hi Tom,
Kinetis L series is using different platform with Kinetis K series, there also with modules difference.
We don't have the register leave comparation table, while I attached K20 50MHz product modules feature comparation with KL series product slide for your reference.
Wish it helps.
B.R.
Ma Hui
