I am trying to use I2c-test tools for verify my I2C0 bus in I.MX28 BSP on I.MX28 EVK, could you please provide me the link how to use it in the shell of rootfs for verifying my I2c driver, I2c0 bus, as I want to evn read & write the data using i2c-test tools into EEPROM
Thanks in advance,
Solved! Go to Solution.
The internal ADC and I2C are different peripheral blocks on mx28, so not sure why you mentioned that they are connected somehow?
Thanks a lot for your quick reponse,
Extremely sorry for consuming your time, query was posted unknowingly
