LVDS display out 720p at 1080P panel
1,522 次查看
alenguo
hi all:
      we use ldb display  out  1080P  is normal. but customer required display 1280*720
      i modify ldb.c add
         ldb_modedb[] = {
         "LDB-720P60", 60, 1280, 720, 13468,
        50, 38,
         20, 29,
         2, 1,
         FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT,
        FB_VMODE_NONINTERLACED,
         FB_MODE_IS_DETAILED,},
     Lvds display out is error,
     i use sabersd_6q board ,lvds panel is auo M215HW02 V0
标签 (2)
1 回复
1,011 次查看
jamesbone
Let me give you my two cents,
It seems that the changes you made are correct but did you change the bootargs so this Video Mode be enable at runing something like
video=mxcdi0fb:RGB24,1920x1080M@60
