The application note AN4764 describes the use of a small footprint (4Kb) USB HID bootloader for Kinetis K and L uC. The document make explicit reference to a IAR project, named "kinetis_L_USB_HID_Bootloader\build\iar\kl25z_HID_Booltoader\kl25z_Lite_Bootloader.eww" and a program named "HIDBootloader.exe", where is available such material?
Solved! Go to Solution.
I'm afraid the app note is quite recent and the code example has not been released, we expect it to be released in a short time however there is not a defined date for this to happen, in the mean time as Dosieto mentions, you could create one using Processor Expert
Hi Gulio,
You are right, couldn't find the archives, but here is the link to another document that tells how to easily create one using Processor Expert: Serial Bootloader for the Freedom Board with Processor Expert | MCU on Eclipse
hope you find it useful.
Dositeo Escobar
Hi Giulio,
Can you provide the link to the Application note?
Here the link to the application note. It has been published in the Kinetis Documentation Section of the Freescale Site.
http://cache.freescale.com/files/32bit/doc/app_note/AN4764.pdf
Hope it can be useful for you.
Giulio
