I am using a MCU51QE128, and I want know how to see the clock speed that was configurate in my MCU using codewarrior development studio - eclipse 10.2 in debug perspective, When I worked in codewarrior 6.3 I could see this speed clock in the command window when this was configured step by step . Somebody know How find this window or what should I do to see the speed clock confugured in my proyects using eclipse 10.2? I want to see something like the picture shows.
My Code:
void Config_Reloj(void){
ICSC1=4; //ajusta el reloj interno
ICSC2=0; //frecuencia de bus de 26´748.225hz
ICSSC=0X70;
ICSTRM=0X40;
SOPT1=0X12; //desactiva el reset
Thanks for your help and apologize for my english
Solved! Go to Solution.
