Hi pgo,
USBDM has problem when I program MC9S08PT32.
first,USBDM can detect chip ID,but can't find chip type.
so,I modify the hcs08_device.xml.and it can find chip type.
so, I program the chip,but another question comes out.
Is it OK to use USBDM to debug MC9S08PTxx?
Hi Wang,
I don't have a PT32 to test with. I tried a PT60 and USBDM had no problems programming my test file. There isn't much difference between the PT32 & PT60 chips and I have checked the device description in the XML file. I can't suggest any reason for the problem. I suggest you have another look at the PT32 entry in the XML and see if you can spot any errors (apart from the missing ID #).
Could you try the following:
Let me know the error message produced.
bye
Hi pgo,
I try again and again according to your suggestion. and result is failed.
I don't know your BDM version.But my BDM version information is as follow:
BDM hardware : USBDM_SWD_SER_JS16CWJ_V2.0
BDM firmware :V4.10.4
USBDM version:V4.10.5
and my test chip is M9S8PT32VLD
