Placing & executing functions from RAM
VictorLorenzo
How can I do for locating/placing several functions in RAM while keeping the rest of the code in FLASH?
Thanks, Victor
VictorLorenzo
I just forgot to say I'm using CW10.4 with GCC. Thanks Lei Mao for your replay.
There's one AppNote at http://cache.freescale.com/files/32bit/doc/app_note/AN4695.pdf which deals with in-software flash programming that also addresses RAM code location. All credits an many thanks to Enric for pointing me to this note.
VictorLorenzo
leimao
you can see IAR k60 example. use __ramfunc to define a function in RAM. good luck
