Hello,All,
I am trying to build gnome environment by using FSL gnome release package.Some error have been solved according to the topic
The error information is :
checking for xsltproc... no
configure: error: XCB requires xsltproc.
error: Bad exit status from /home/chf/ltib/tmp/rpm-tmp.7735 (%build)
RPM build errors:
Build time for libxcb: 20 seconds
Failed building libxcb
f_buildrpms() returned an error, exiting
traceback:
main:560
Started: Mon Jun 3 21:50:10 2013
Ended: Mon Jun 3 22:26:39 2013
Elapsed: 2189 seconds
These packages failed to build:
libxcb
Build Failed
How to solve it?
Haifeng
Solved! Go to Solution.
Sorry, the solution is
sudo apt-get install xsltproc
