Warning -- Freedom Board Crystal/PLL Caution
eli_hughes
Contributor V
WARNING
If you stumble across the "getting started page" FREEDOM BOARD / CORTEX M0+ GETTING STARTED  Please take note:
While working with a large number of Freedom boards in a course,  it was observed that the Init Clock Routines would *sometimes* not work.    *Some* of the crystals on the freedom boards do NOT like "HIGH_GAIN" mode.
change the line
  pll_init(8000000, HIGH_GAIN, CRYSTAL, 4, 24, MCGOUT);
to
  pll_init(8000000, LOW_POWER, CRYSTAL, 4, 24, MCGOUT);
Monica
Senior Contributor III
Eli,
Thanks again for contributing!
Great job! :smileyhappy:
