CW10.3 causes "linker command file error at line..."
ignisuti
I had a project working beautifully with CW10.2. I tried to upgrade to 10.3 and right off the bat I get "codewarrior linker command file error at line...". This error is repeated for every .obj file specified in my linker configuration file.
Any thoughts on what might be causing this?
Tags (3)
BlackNight
it would be very helpful if you could post more details (which processor used, which compiler) plus the error message and linker file used, or an example?
ignisuti
Erich,
Processor: MK10DN512ZVLQ10
Compiler: How can I find this info?
The error messages all start with "linker command file error at line..." and then list all the line numbers where I list.obj files.
Problems: http://dl.dropbox.com/u/438946/Permanent/Problems.txt
LCF: http://dl.dropbox.com/u/438946/Permanent/MK10DN512Z_flash.lcf
ignisuti
I'm still unable to move onto CW 10.3. If anyone has any suggestions, please let me know. Freescale technical support has been very unhelpful.
