Back porting UVC camera support to Adeneo R4.0 version
PSC1z
Hi all,
Since I've made lots of modification on R4.0 and therefore I would like to back porting the UVC camera support to R4.0 from R4.1 instead of migrating all the stuff to R4.1.
I've checked the /src/hardware/mx5x/libcamera/ and seems no big different.
Do anyone has advice on how to migrate the UVC camera code back to 4.0?
Thank.
rlorriaux
You just need to make a small change in libcamera. If you look at the Quick Start Board patch on 4.1, you will see it. It should be sufficient to support the UVC camera.
R Lorriaux - Adeneo Embedded
