Alban wrote:Cannot you use a 4.9152MHz crystal in your application and any frequency canned oscillator for programming ?I don't see anything forcing you to have the same clock for both, as you will not execute in MON08 but just program the Flash. The only impact is a change of baud rate.Alban.
