Hello, everyone!
During our project design, we need use CAN bus on MX287 EVK with Linux , but we have found FSL hasn't added it in original BSP. does anyone hase success experience and help indicate? thanks
I believe CAN bus support is in the LTIB distribution. Please check with
ifconfig -a
if you see the can0 and can1 interfaces
HTH,
Matteo
the mainline kernel has CAN support on MX28. If you want to stay with the FSL BSP you can maybe port the relevant patches back.
Robert
