PPP over GPRS link (Error)
G_rio
Hello all,
I'm trying to connect 3G modem on i.MX53 and i followed this site http://foxlx.acmesystems.it/?id=13 but i got this error:
WARNING: couldn't open ppp database /var/run/pppd2.tdb
Does anyone know how to fix it ?
G_rio
Thank you very Much, it worked properly
rlorriaux
Fresh Out Contributor
Make sure there is enough space for /var:
  • ./ltib -c
  • Target image generation
  • tmpfs size: as much as required (start with 4096k, keeping in mind that it is mounted in RAM by default)
By default, the size of the tmpfs fileystem where /tmp and /var are mounted is only 512k and it fills up pretty quickly.
