Greetings all
Task:
Use the timer module to create a series of pulses with predefined length.
My solution:
Setup the timer module as edge-aligned PWM and set teh proper frequency and duty cycle. Then activate output compare interrupt and count the number of output compares until the desired pulses has been met. Then set the duty cycle to zero to stop the pulses.
Code implementation #1:
This code almost works. If i set PulseCount = 10, then the first two output compares happens right after each other, so theres no pulse to be measured on the output. The final 8 pulses gets transmitted just fine.
I've tried resetting the main counter in the PushUpBtn and PushDwnBtn with no change in behaviour.
; Initialization code
ldhx #28000
sthx TPMMOD
ldhx #0
sthx TPMC1V
sthx TPMC0V
mov #$0F,TPMSC ; Store settings - No TOF interrupt needed.
mov #$28,TPMC1SC ; Enable output compare interrupt, edge-PWM
mov #$28,TPMC0SC
; PushUpBtn
PushUpBtn:
pshhx
ldhx #PULSE_LEN
sthx TPMC0V ; Set the pulse length
pulhx
rts
PushDwnBtn:
pshhx
ldhx #PULSE_LEN
sthx TPMC1V ; Set the pulse length
pulhx
rts
; isrTPMCH1
; Timer output compare interrupt
; This interrupt is used to count the number
; of pulses sent to AP110. It decrements the
; PulseCount and stops the PWM when it reaches
; 0x00 in PulseCount
isrTPMCH1:
lda TPMC1SC
and #$7F ; Clear the output compare flag
sta TPMC1SC
dbnz PulseCount,isrTPMCH1End
ldhx #0
sthx TPMC1V
isrTPMCH1End:
rti
; isrTPMCH0
; See description of isrTPMCH1
isrTPMCH0:
lda TPMC0SC
sta TPMC0SC
dbnz PulseCount,isrTPMCH0End
ldhx #0
sthx TPMC0V
isrTPMCH0End:
rti
Code implementation #2:
This code won't work at all. The output compare interrupt triggers fine, but the output stage on the pins never change. I can't figure out why this happens?
ldhx #28000
sthx TPMMOD
ldhx #0
sthx TPMC1V
sthx TPMC0V
mov #$28,TPMC0SC
; PushUpBtn
PushUpBtn:
pshhx
bclr TPMC0SC_CH0IE,TPMC0SC ; Disable interrupt
sthx TPMCNT ; Reset the main counter
ldhx #PULSE_LEN
lda TPMC0SC
ora #$40 ; Enable interrupt @output compare
sta TPMC0SC
pulhx
rts
PushDwnBtn:
pshhx
bclr TPMC1SC_CH1IE,TPMC1SC ; Disable interrupt
ldhx #PULSE_LEN
lda TPMC1SC
sta TPMC1SC
pulhx
rts
; isrTPMCH1
isrTPMCH1:
lda TPMC1SC
sta TPMC1SC
ldhx #0
sthx TPMC1V
isrTPMCH1End:
rti
; isrTPMCH0
isrTPMCH0:
lda TPMC0SC
sta TPMC0SC
ldhx #0
sthx TPMC0V
isrTPMCH0End:
rti
In both code implementations the vector table looks like this:
ORG $FFF2
dc.w isrTPMCH1
dc.w isrTPMCH0
Anyone got some ideas how to get the timer module to send out 10 well-defined pulses if i set PulseCount = 10?
