Always a pleasure ...
I will study your code - I have read somewhere that you start with the EPHY, get it running and then do the FEC
Q : Can you get the EPHY to connect, ( 100mbs, F/D A-N) without starting up the FEC?
I have attached my forth code, FYI
I have not used Forth in years, but I can attest to the accuracy of John's statement. I do not consider Forth a high-level language, but a mid-level language, somewhere between assembler and C. This makes it suited for embedded development.
Jaux wrote:
. . . Here the emphasis is on speed and code-size and I have found that the code generated by SwiftX is so much more compact, reliable and faster than code generated by CW and others.
Message Edited by rocco on 2007-01-0101:10 PM
