Hello
Peripheral builder is a separate product.
It does not provide you with additional simulation features. It makes the debugger an open framework and allows you to extend the simulator with new components.
The peripheral builder allows you to implement additional component yourself.
Also Peripheral builder is basically working for 8-16 bit products only (HC(S)08, HC(S)12(X)).
CrasyCat
