I am using CW for Palm to create a project which needs loops.
My project has two loops, one nested inside the other.
There is an Abort button and I have put the following code inside the innermost loop which is basically a timer:
EvtGetEvent (&event, 5);
if( event.eType == penDownEvent)
{tester = 1;
return;}
Then in the other loop I have:
if (event.screenY < 132) continue;
else if (tester = 1)
{tester = 0;
FrmGotoForm (WelcomeForm);
CurrentView = WelcomeForm;
return errNone;}
This gets the job done OK but I would appreciate any advice as to whether this is acceptable method.
I really don't know of any other way to get out of the loop.
Barry
