Hello Peg,
Are you operating with "simulation only", or are you driving some hardware? I am reminded that, for the MMEVS with the M68EML08QTQY emulation module, two of the vector locations have been moved, including the KBI vector (to $FFE4). I wonder if part of your problem might be of this nature.
Mac
Hi Mac,
Simulation only!
The KBI problem I found several months ago and know my code works on real hardware. In full simulation you only get to simulate your KBI interrupt code over and over once you set level sensitive.
The OSC2EN problem I only discovered the other day after I sent every device I had out for field testing. They reported an issue so I was doing a full simulation and found 1 input didn't work in the simulation.
BR,
Peg
Hi all,
These two issues have now been acknowledged by Mark Cukier of P&E and have been noted for correction in the next release.
BR Peg
