Will EDS Client make it into a future Freescale MQX distribution? This is a critical troubleshooting tool for live systems. This is especially true when JTAG connections are not possible and only Ethernet links are available.
Solved! Go to Solution.
Hi pmt,
do you mean this tool? http://www.embedded-access.com/products/host_tools.html
MartinK
Hi pmt,
MartinK
Yes,
MQXDebug EDS Client. This is not in the current distribution of Freescale MQX per the release notes.
Just talked to EA. Appartently this will be released at some point in the future as an Eclipse plugin.
Chris
