Hi sheng Cao
Yes, you can.
In fact, the serial download mode is copy the flashloader firmware to the internal RAM, and then jump to the Flashloader address.
痞子衡嵌入式:恩智浦i.MX RT1xxx系列MCU启动那些事(3)- Serial Downloader模式(sdphost/MfgTool) - 痞子衡 - 博客园
So, you also can copy the flashloader firmware to the internal RAM in your own app, and jump to it.
The flashloader can be found in the RT SDK, which can be downloaded from this link:
Welcome | MCUXpresso SDK Builder
Wish it helps you!
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
Hi sheng Cao
Yes, you can.
Wish it helps you!
Wish it helps you!
Kerry
Hi Kerry
I have similar question about burning eFUSE (BT_FUSE_SEL).
If eFUSE (BT_FUSE_SEL) is burned.
It cannot enter download mode automatically by BOOT Mode GPIO(BOOT_MODE0, BOOT_MODE1).
If you want to enter download mode, it need copy the bootloader to SRAM and Jump in your application(manually).
Is my understanding correct?
Ken
