i.MX RT1060 continuous spi read
Showing results forย
Search instead forย
Did you mean:ย
erintel
I want to read data from an external ADC (AD7380 https://www.analog.com/en/products/ad7380.html) over SPI and DMA with equidistant sampling at ~100kSPS.
To initiate the conversion process the CS has to be pulled down and the result clocks out on the serial output pin.
Just to test the ADC I am calling LPSPI_MasterTransferEDMA in a general purpose timer.
Can I control the CS with a GPIO?
I just need a starting point or an idea how to handle this problem.
FelipeGarcia
Yes, CS can be controlled with GPIO but you will need to control it manually.
Felipe
