eIQ portal server encountered error
1,911件の閲覧回数
lewis_huang517
Hi,I am Lewis.
When I clicked "start trainig" button,I got this error message.
Does anyone know a solution?
19 返答(返信)
1,874件の閲覧回数
kerryzhou
Hi @lewis_huang517 ,
  Which EIQ tool version you are using?
  Do you try the newest version or not? Whether the same issues?
  Please also tell me your used RT chip partnumber, thanks.
  Any updated information, kindly let me know.
kerry
1,859件の閲覧回数
lewis_huang517
Hi kerry.
Thanks for for your reply.
My eIQ toolkit version is V1.6.9 and I installed V1.8.0 yesterday.
But when I tried to use V1.8.0 and clicked it. There is no responds.
My RT chip is MIMXXRT1170.
 Best Regards.
1,744件の閲覧回数
kerryzhou
  Which PC OS you are using now?
   Do you read the tool release note, whether your platform meets the requirement?
Kerry
1,739件の閲覧回数
lewis_huang517
Hi kerry.
My os is windows11.
And I read the User Guide , make sure my dataset is correct. This dataset is CrowdHuman. But there are no problem when I used another Dataset about Human Detect.
Lewis
1,731件の閲覧回数
kerryzhou
  I have downloaded and installed the eiq v1.8
Please tell me the detail steps to reproduce your issues from the very beginning, I mean, from here:
Step by step to reproduce your issues, then I can try to check it, if I also reproduce it, I will report it internally, thanks.
Kerry
1,710件の閲覧回数
lewis_huang517
Hi Kerry,
Thanks for your reply. But I have to say sorry for my mistake. My PC OS is ubuntu20.04,not windows 11.
And my ubuntu cannot use eIQ portal v1.8 because when I clicked it.There is no reponsed. I dont know why. So I used v1.6.
This is my step for deployed Crownd Human Dataset.
First I choose import dataset. Then I clicked VOC- Dataset Button.
This is my Dataset Folder.  Including Annotations and Images.
Then I clicked  "IMPORT" -> "SELECT MODEL" -> "Classification" -> "Performance" -> "MCU" -> "START TRAINING"
Batch Size : 10
Epochs : 30
Scale : small
Then I got this message.
1,703件の閲覧回数
kerryzhou
Hi @lewis_huang517 .
  Please share your Dataset Folder.  Including Annotations and Images.
as I lack it:
I want to also use your database to test it, although I am using the windows, just double check it, whether it is related to your Dataset Folder.
kerry
1,687件の閲覧回数
lewis_huang517
Hi,Kerry
And this is my Dataset. Thanks for your help.
CrowndHuman.zip
Lewis
1,653件の閲覧回数
kerryzhou
  I download your 10G CrowndHuman.zip, but when I unzip it, i always meet the following issues:
Do you have this issues to unzip it?
I am afraid this unzipped issue package also can't be used.
kerry
1,604件の閲覧回数
lewis_huang517
Hi,Kerry.
I dont know whats wrong with my dataset. I just zip it.
But I download my dataset form this website.
Maybe you can try it.
https://www.crowdhuman.org/download.html
Lewis
1,593件の閲覧回数
kerryzhou
  which one you have tried?
Kerry
145件の閲覧回数
die1234567890
When the eiq portal version 1.9 encountered error:Target not found: Error: URL_UNAVAILABLE When verifying the model, what do I do
1,589件の閲覧回数
lewis_huang517
Hi,Kerry.
That is whole dataset. Including
CrowdHuman_train01,
CrowdHuman_train02,
CrowdHuman_train03.
Please download all and merge it.
Lewis
1,579件の閲覧回数
kerryzhou
   Thanks, I will try it again.
   The dataset is trained by yourself, or the 3rd part working dataset?
Kerry
140件の閲覧回数
die1234567890
Hi,@Kerry zhou
Validation encountered error:Target not found: Error: URL_UNAVAILABLE when I verified the model using version 1.9 eiq portal
Validation error encountered: Target not found: Error :URL_UNAVAILABLE
What to do
82件の閲覧回数
kerryzhou
Hi @die1234567890 ,
  If you have any issues, could you please help to create your own question post, thanks.
  Then, we will help you in your own question post, thanks.
Kerry
1,488件の閲覧回数
lewis_huang517
Hi,Kerry.
I just download  this dataset and train it by my own model.
But eIQ Portal can't train it.
Lewis
1,444件の閲覧回数
kerryzhou
  Sorry for my later reply, really a little overflow these days.
  Do you download your upload folder:
CrowndHuman.zip
  Whether you can unzip it or not?
  If I download the website which you mentioned, how to merge it, do you mean, I download the :
CrowdHuman_train01,
CrowdHuman_train02,
CrowdHuman_train03.
unzip the above zip, and merge the files to one folder, right? what about annotation folders?
kerry
1,419件の閲覧回数
lewis_huang517
Hi,Kerry.
If you download this Dataset.
Just merge it.
For example,unzip CrowdHuman_train01,CrowdHuman_train02,CrowdHuman_train03,
and copy file to train folder.
And you can get train dataset.
Lewis.
