Getting this error after running rtwdog timer and forcing a reset by failing to refresh it on purpose on the RT 1020. How do I prevent this, as it completely shuts down my debugger and does not let me test the functionality of the timer on my system upon reset. My debug mode is active in config, and my enable and stop modes are turned off
Alongside this I am also getting this message that pops up each time the watchdog trigger happens
Seems something at this memory address is causing it to break. How can I access this address and perhaps resolve my error?
Hi @ikuzmych ,
ROM bootloader is start from 0x200000. When you debug the rtwdog example, every time when it reset, it will stop at ROM bootloader. You can set a break point at main(), then click the Resume button, the MCU can continue to execute to the break point.
Jing
