Stack for pdf generation
985件の閲覧回数
Nagakalyan
I am doing my http server program in that i want to generate the pdf and send to the browser.But i am unable to find the proper stack for pdf generation. i am using imxrt1064 -evk board
8 返答(返信)
976件の閲覧回数
kerryzhou
Hi Nagakalyan,
   Thank you for your interest in the NXP MIMXRT product, I would like to provide service for you.
   I also didn't find any pdf stack for the lwip in the embedded MCU system.
  I think you can consider use the http server send the data to the PC, and use the PC windows to generate the pdf.
Wish it helps you!
If you still have questions about it, please kindly let me know!
Kerry
974件の閲覧回数
Nagakalyan
Thank you for the response if any stack is there,pls let me know .
962件の閲覧回数
kerryzhou
Hi Nagakalyan,
   I will also help you to check with my colleagues.
   But to be honest, I didn't see that stack in the previous time.
Wish it helps you!
Kerry
946件の閲覧回数
Nagakalyan
Thank you for the reply, so we can have alternative that we can send the data to the browser or client then client will produce the data in pdf file but if we have pdf stack then for client side the burden will reduce,so for that purpose i am trying for the solution.
944件の閲覧回数
kerryzhou
Hi Nagakalyan,
  Unfortunately, we don't have the PDF stack.
  If you need to send the data to the browser, you can check the lwip_http project in the SDK.
Wish it helps you!
Kerry
928件の閲覧回数
Nagakalyan
http://libharu.org/ In this webiste there is a stack for pdf generation but some of the headers are not supported.
914件の閲覧回数
Nagakalyan
any suggestions for pdf generation?pls let me know
901件の閲覧回数
kerryzhou
Hi Nagakalyan,
    I think your provided the link is not for the embedded MCU, it is the windows side code.
    We mainly provide the MCU side technical support.
    As I know, the MCU don't have the pdf stack, we mainly use the HTTP sendout the data through the ENETH module, other things, you need to check the windows side code.
Wish it helps you!
If you still have questions about it, please kindly let me know.
Kerry
