Keil Support in SDK 2.8.4 and 2.8.5
Search instead for
carstengroen
Senior Contributor II
Why is it no longer possible to select Keil support for the newest SDK versions (for 1064 and 1062) ??
Both 2.8.4 and 2.8.5 does NOT list Keil anymore as toolset. I hope this is an error and not a new route NXP is taking !?
victorjimenez
Keil MDK support is not included with SDK v2.8.5.  We currently recommend that you use SDK v2.8.2.  Support for Keil MDK will be included in SDK v2.9.0.
Victor
- If this post answers your question, please click the "Mark Correct"button. Thank you!
carstengroen
@victorjimenez ,
thanks a lot! No problem for us to continue to use 2.8.2 for now, we were just worried that somehow Keil MDK support was to be removed altogether, which seems not to be the case with your comment.
Thanks!
victorjimenez
Victor
