RT1052 LPUART FIFO depth is only 1?
lixiaotian
the LPUART Parameter Register (PARAM) is read as 0. So what is the meaning of the fifo?
1277185193
jeremyzhou
Hi li xiaotian,
Please check the LPUART[FIFO] register.
TIC
1277185193
Excuse me ...How to change the fifo depth? This field is read only......B8JKEAKPH0~9X6(7E_{784D.png
jeremyzhou
Hi 卢 鲲,
Thanks for your reply.
It's not able to customize to configure the depth of the buffer, you only can enable the buffer or discard this feature.
TIC
1277185193
  • OK!  Excuse me ......Are you an official with NXP ?
    It's so unbelievable...Why are there so many options of fifosize?
