I am very new to MXRT1050EVKB. I am trying to control with PWM signal. I have configure a pin as pwm1
peripheral. The pwm signal has also generated.But what more i should do control brightness of LED..what more have to implement and how?Please help
Solved! Go to Solution.
Within the SDK for the RT1050-EVKB you will find a PWM example. This is a good starting point for your application. If you want to see the PWM through an LED, you have two options:
Victor
Victor
