Failed to compile a project on mcuxpresso case running a video on MIMXRT1170 EVKB
Mira1
I'm trying to compile a project on both MCUXpresso v11.9.0 and v11.8.0 with different version of the SDK, but I encountered an error, missing files (ff.h and sdcard. h), the purpose of the project is to run a video on MIMXRT1170 EVKB bored. I generated the project on Guiguider V1.6.0 and I copied the video file           (*. h264) to the SD card.  How can I fix that?  thank you.
Habib_MS
Hello @Mira1,
At the moment GUI GUIDER does not support this widget on the RT1170 EVK and EVKB, but we are currently aware of this issue, and it is expected that within the next few versions it will be supported.
Sorry for the inconvenience this may cause.
Habib.
Mira1
Hello @Habib_MS ,
So, is there an alternative for this the time it will be settled on guiguider?
Thank you.
Habib_MS
Hello again @Mira1,
GUI GUIDER do not have any tool like that but is expected that within the next few versions it will be supported.
Habib.
Habib_MS
Hello @Mira1,
Habib.
