I'm developing a board with an i.MX RT 1052 and I'm trying to use the touch screen controller driver fsl_tsc (version 2.0.3) for a 4-wire resistive touch screen.
The reference manual (MCUXpresso SDK API Reference Manual: TSC: Touch Screen Controller Driver (nxp.com)) mentions there should be examples in <SDK_ROOT>/boards/<BOARD>/driver_examples/fsl_tsc but there are none. I've also checked by filtering in the SDK builder (Select Example | MCUXpresso SDK Builder (nxp.com)), but it appears there are no examples in any SDK.
I've read the documentation in the header file and the one in the i.MX RT 1050 reference manual but I'm still not sure what are all the requirements to get the fsl_tsc driver to work, including the settings for the ADCs.
I would appreciate if someone had a working example, or at least a guideline on how to proceed to get the coordinates detection to work.
Thank you,
Enrico
已解决! 转到解答。
Hi @EnricoLusa ,
Already send the TSC examples in the private message for you.
You can check it.
Wish it helps you!
Kerry
Hi @Hadron
If you need the TSC example, please use your company email create the account and the case, following this steps:
1. Open below SUPPORT site, click blue "Go to Tickets" in the middle.
http://www.nxp.com/support/support:SUPPORTHOME
2.Then you will be requested to Login, if you have no an account, please first Register with your business email.
3.After login, please "Create New Cases" button in the middle, then you can submit your question.
Then we will send you to your email.
kerry
Hi @shchu ,
kerry
