Examples for fsl_tsc
1,286 次查看
EnricoLusa
I'm developing a board with an i.MX RT 1052 and I'm trying to use the touch screen controller driver fsl_tsc (version 2.0.3) for a 4-wire resistive touch screen.
The reference manual  (MCUXpresso SDK API Reference Manual: TSC: Touch Screen Controller Driver (nxp.com)) mentions there should be examples in  <SDK_ROOT>/boards/<BOARD>/driver_examples/fsl_tsc but there are none. I've also checked by filtering in the SDK builder (Select Example | MCUXpresso SDK Builder (nxp.com)), but it appears there are no examples in any SDK.
I've read the documentation in the header file and the one in the i.MX RT 1050 reference manual but I'm still not sure what are all the requirements to get the fsl_tsc driver to work, including the settings for the ADCs.
I would appreciate if someone had a working example, or at least a guideline on how to proceed to get the coordinates detection to work.
Thank you,
Enrico
1,278 次查看
kerryzhou
Hi @EnricoLusa ,
     Already send the TSC examples in the private message for you.
    You can check it.
Wish it helps you!
Kerry
6 回复数
1,279 次查看
kerryzhou
Hi @EnricoLusa ,
    You can check it.
Wish it helps you!
Kerry
1,158 次查看
Hadron
Hi,kerryzhou
Could you sent the TSC examples to me?Thank you very much.
Best regards!
1,149 次查看
kerryzhou
Hi @Hadron
  If you need the TSC example, please use your company email create the account and the case, following this steps:
1. Open below SUPPORT site, click blue "Go to Tickets" in the middle.
http://www.nxp.com/support/support:SUPPORTHOME
2.Then you will be requested to Login, if you have no an account, please first Register with your business email.
3.After login, please "Create New Cases" button in the middle, then you can submit your question.
Then we will send you to your email.
kerry
1,181 次查看
gossipboy
Hi,kerryzhou
Could you sent the TSC examples to me?Thank you very very much
Best regards!
1,167 次查看
shchu
Can I get a copy of the TSC example code too?  Thank you very much.
-Jeffrey
1,161 次查看
kerryzhou
Hi @shchu ,
kerry
